5.9 gas multi misfire codes
Old May 7, 2012 | 07:00 PM
Soup is on.'s Avatar
Soup is on.
Default 5.9 gas multi misfire codes
Hey, got an 02 ram 1500 quadcab 4x4 with 180k. Codes P0300, P0301, P0302 and P0307. I know that these are misfires on cylinder 1,2 and 7. These are also inline with each other on the distributer. Any ides as to what could cause these three to misfire. I know the obvious would be to start with new plugs, plud wires, can and rotor. But could it really be that easy of a solution or is there something else that typically causes this? Any help would be great, thanks
Old May 7, 2012 | 07:02 PM
Ham Bone's Avatar
Ham Bone
I had misses similar to that. Full tune up cap, rotor, plugs, wires and the truck was brand new.
As cheap as that Is there's no reason no to just go ahead and do it
Old May 7, 2012 | 07:17 PM
Augiedoggy's Avatar
Augiedoggy
likely a worn rotor and cap.... possibly something more serious but like ham bone said... start with the cheap and regularly needed maintenance and get all that in order first..
Old May 7, 2012 | 07:20 PM
Matt Nickerson's Avatar
Matt Nickerson
Well if you haven't done a tune-up in a while, you need to anyways. It may fix the problem. You could also pull the plugs on those cylinders you got codes for and check their condition.
At 180K miles a fuel pump failure could be a culprit as well...rent a fuel pressure gauge and test how much psi its pushing out.
Ignition coils can also go bad and set off a p0300. Grab your service manual and look up how to check the coil with a multimeter.
So, I'd start with a tune-up and go from there.
Old May 7, 2012 | 10:04 PM
Soup is on.
yah i think that'd prob be the first order of business. I haven't owned the truck for very long, so who knows the last time it had a tune up. Thanks, if prob still persist, i'll be back
Old May 11, 2012 | 05:33 PM
Soup is on.
so i went to my local parts store to get cap and rotor but they don't have a listng for such parts. is this gonna be a dealer thing or does anyone have any other suggestions. dealer's prob gonna be a bit pricey
Old May 11, 2012 | 05:58 PM
Augiedoggy's Avatar
Augiedoggy
that doesnt make any sense.... they have them in stock at all the local parts stores around me?.... these are very common engines...
I just bought mine on ebay...* bucks for cap and rotor together shipped... and like 18 bucks for the smp wire set.... o2 sensors are 21 shipped... pretty much everything is cheaper... and you can choose your brand preference... brake pads and such are better sourced locally because of warranty..
Old May 11, 2012 | 11:17 PM
Soup is on.
yah that's kinda what i thought but haven't checked anywhere else yet. It's my weekend projech.
Old May 12, 2012 | 11:41 PM
Soup is on.
got the cap and rotor changed today, went to oriellys. still have plugs and wires to do but already seems to run better. then it's time to turn to the real problem, damn trans...
