Fm went out
Old May 8, 2012 | 12:13 PM
PmuLLin's Avatar
PmuLLin
Default Fm went out
I was listening to my radio on fm and it just cut out am work the cassette deck works and ten I change it to fm I hear static my antenna is still attached and not bent I checked the fuses real quick but I was in a rush did I just over look it? I didn't think their was one
Old May 8, 2012 | 12:16 PM
No fuse for the antenna, or just the FM band. Either the radio died, or, the antenna came unplugged from the radio.
Old May 8, 2012 | 03:31 PM
PmuLLin's Avatar
PmuLLin
Do I need to pull the dash to check where the antenna is plugged in ?
Old May 8, 2012 | 03:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It plugs in to the back of the radio. Need to remove the bezel and some screws.
Old May 8, 2012 | 03:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Maybe your hearing aids need new batteries?
Old May 8, 2012 | 03:37 PM
stewie01's Avatar
stewie01
Should just have to pull the bezel off and there should be 2 or 4 screws that hold the radio in place, take those out and pull out your radio, see if anything is disconnected.
Edit:
zman beat me to it
Old May 8, 2012 | 03:39 PM
Jigabop's Avatar
Jigabop
good excuse to upgrade to an aftermarket deck!
Old May 8, 2012 | 04:57 PM
JamesG's Avatar
JamesG
I just bought my '98 1500 and all I get is AM. Only static on FM. I wonder too if the antenna came loose or is this an issue with these radios.
Old May 8, 2012 | 05:08 PM
stewie01's Avatar
stewie01
Jigabop's got the right idea!
Old May 8, 2012 | 05:50 PM
dlyter09's Avatar
dlyter09
That happend in both of my trucks.. wasnt a big deal i just replaced it with a better aftermarket unit which is what i would recommend... Happend in my Jeep but that was my fault.. the water was deeper than i thought
