Old Aug 6, 2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
A/C leaking water under passenger side dash. Condensation drain hose.
Old Jul 6, 2017 | 01:39 AM
Mike Bothwell's Avatar
Mike Bothwell
Default I have the same issue. Thank you.
I've been dealing with water in the floorboard for about two weeks. It was a week or so ago that I noticed a drip coming from the dashboard and surmised that it was coming from the condenser. I thought I was going to have to get into the dashboard but, if your fix works, I'll be ecstatic. You are a saint sir, for taking the time to share this information and I appeciate it immensely. Thank you.
Old Jul 8, 2017 | 09:37 AM
Spillage's Avatar
Spillage
I used a short 90° rubber elbow (Dorman) from one of the auto parts stores... it was a perfect fit over the drain.
I think it was intended for a PCV line.
Old Jan 3, 2018 | 11:17 AM
JT Schneider's Avatar
JT Schneider
Exclamation Random tube coming up
I recently am trying to find out why my 98 Dodge Ram 1500 5.9L has no heat I replaced the thermostat and it didn’t help. I found a tube coming up by manifold that is long enough to go onto condenser drain. Does this hose belong on the drain? Is this why I don’t have any real heat ??
Old Jan 3, 2018 | 02:13 PM
Nothing goes to the drain, it's just a drain. What's that tube look like? Does your engine get up to temp?
