Disappearing oil. NOT PLNEUM
Old May 11, 2012 | 09:34 AM
According to Dodge..... anything over 100 PSI dry is 'acceptable', with all cylinders within 25% of each other...... obviously, the higher the number, the better..... but, even 150 PSI compression does not tell you a thing about the condition of your oil control rings....
Old May 11, 2012 | 04:27 PM
jarebear86's Avatar
jarebear86
So how am I supposed to find that out
Old May 11, 2012 | 04:33 PM
Augiedoggy's Avatar
Augiedoggy
compression test will usually tell you a lot....
