The tab is just for alignment. Looks like your going to need heat, a lot. If at all possible, right where the pipes are creased from the clamp, heat it the whole way around until its glowing red. Then grab the pipe with vise gripes on the end and start smacking it with a hammer to work it out. All while reheating if needed.
still no luck, am i able to cut it at the crease? Say the flange is 6 inches, if i cut it at the crease there would be about 3 or so inches left for me to slip in the new cat and clamp it down. Would that be enough for the cat to slip in and clamp down?
ok if i get a coupler like you say do i have to weld it or can i just clamp it? thatll be much easier, ive been heatin it poundin it wrenchin and it doesnt want to come out. Its moved but not much.I figure also the new one probably wont go in very easy anyway IF i did get the old one out.
Welding is better, but clamping can work. A muffler shop may weld it in for a little bit. I had a 3" end piece with one bend about 24" long welded in and cost about $35.
I dont have any shops close by and dont know if i could get it there anyway. This thing is probably the most difficult thing ive done to this truck yet..plenum,timing chain,rear main seal..nothing as frustrating as this..haha
I just talked to my father in law and he has and acetalyn(spelling??)torch to get it real hot, can i put my new cat on and some how tie it of to the side so i can drive about 10 min to his house?
ok i didnt know if running it with just the cat would hurt anything or not. right now im using just a hand plumbers torch but thats not really cuttin it. i found theres a exhaust hanger at the end of the cat so that should hold it up as long as it wont hurt anything thats what ill do.
