help with axle seals
Old May 18, 2012 | 02:29 PM
mj23polaris's Avatar
mj23polaris
Default help with axle seals
Doin front axle seals on my truck wanted to know if anyone knew of and write ups on how to replace em, or could someone just explain what i got to do. Thanks
Old May 18, 2012 | 02:37 PM
4x4? If so..... axle seals are a right pain... gotta completely disassemble the axle..... tires/wheels, hub/bearings, pull the axles, cad housing, cover, differential itself... drivers side seal is in there..... passenger side seal is got at thru the cad housing hole.
Procedure is in the service manual. (you did download one from the faq section, right? )
zman17's Avatar
zman17
Retired Moderator - RIP
Got the free service manual and a Haynes yet? Nobody can splain on the internet what you need to do, without writing a service manual them selves. This is a big job to do both sides.
Old May 18, 2012 | 02:50 PM
mj23polaris
Ok well in doing a locking hub swap so knuckles, n shafts are out, putting new bjs in and u joints, the only one leaking is my passenger side, do i need a spreader for the housing to get carrier out? I've heard that i do and i don't.
Old May 18, 2012 | 02:56 PM
zman17's Avatar
zman17
You might or might not need a spreader. Sherrif420 used a come along to pull his out, and some will just fall out. My 98 just came out when I did the driver side seal. No spreader or pulling.
Old May 18, 2012 | 02:59 PM
mj23polaris
Edit!! Typo its drivers side that leaking. What special tool do i need?
Old May 18, 2012 | 03:02 PM
redneck_ram's Avatar
redneck_ram
kinda interested in knowing if there is a write up for this as well. my front axle seals are leaking too, and other than knowing i have to completely disassemble everything, id kinda like a write-up and pics, that i can go by.
Old May 18, 2012 | 03:09 PM
mj23polaris
Ill do the best i can on a write up when i do it, same with my hub swap
Old May 18, 2012 | 03:15 PM
zman17's Avatar
zman17
Edit.....
Old May 18, 2012 | 03:21 PM
zman17's Avatar
zman17
You need no special tool for the driver side. You just have to take the whole diff apart to replace it. Then you'll need the special tool to install the passenger side seal. Which I have. I can help redneck with this, but he does everything without a manual. LOL, JK bud.
If you need help, I'm available like in the past.
