Turning off power windows
Old May 18, 2012 | 02:55 PM
krichards6405's Avatar
krichards6405
Default Turning off power windows
Does anyone know if you can temporarily disable the passenger and driver side front window? I need to get my truck inspected and my tint is to dark, but if can role the window down and disable it, maybe i can pass.
Old May 18, 2012 | 03:03 PM
ramitt360's Avatar
ramitt360
there are fuses on the side of the dash for those windows, Pull em. Or you could do it the harder way by taking the door panel off and unplug the power lock/window plug.
Old May 18, 2012 | 03:08 PM
krichards6405
ok awesome I didn't know if a fuse would work. Im at work and had a brain fart and thought that would be the best way to get it past inspection. that is unless the check the fuse panel also
Old May 18, 2012 | 03:34 PM
peshewa's Avatar
peshewa
When I used to live in Dallas, I could not pass inspection if my windows would not roll up. Glad I'm not there anymore - at least until winter kicks in hard here in Iowa.
Old May 18, 2012 | 05:34 PM
krichards6405
I would gladly take your Iowa winters vs south texas summers. but i wonder why windows would cause your truck not to pass? can jeeps without doors get passed?
Old May 18, 2012 | 06:04 PM
ramitt360's Avatar
ramitt360
I used to live in Maine so I know about the winters and inspections. Not really allowed to lift or lower suspension or body lifts.. they say the body lift affects your stopping. There is a frame height law but at the same time say no to altering your suspension. You are only allowed 2 tire sizes bigger or smaller than stock. Of course due to the crap they put on the roads during winter, you cannot have rust holes anywhere. I live in Florida now and they have no inspections which is good. However I didn't know what hot was til june july and august rolled around. It's not fit for humans here without A/C and I must say I'd rather be cold than miserable hot. You can dress for the cold you can't dress for the heat.
Old May 18, 2012 | 06:09 PM
krichards6405
That is the truth!! When its cold you can always add more clothes. I can only take off so much before it becomes illegal.
Does anyone know if you have to have working windows to get an inspection?
Old May 18, 2012 | 06:16 PM
krichards6405
Just got out of work and called a couple shops that do inspections everyone of them told me working windows dont matter. So lesson learned: If you got tint that is to dark, roll windows down and pull the fuse.
Old May 18, 2012 | 06:20 PM
stewie01's Avatar
stewie01
Or move to Georgia, they don't do vehicle inspection's!
Old May 18, 2012 | 06:22 PM
krichards6405
good point
