cant get shocks off
Old May 18, 2012 | 06:10 PM
cutthroatxxx's Avatar
cutthroatxxx
Default cant get shocks off
Well I just can't get my front shocks off,the bolt for the bottom,Ive hit it with pb,air ratchet, impact...they just will not budge!
Old May 18, 2012 | 06:22 PM
stewie01's Avatar
stewie01
If you're desperate you could try a little heat, a standard size blowtorch would work. Is the metal piece (name?) on the inner part of the control arm that the bolt goes through catching so the bolt can be removed?
Old May 18, 2012 | 06:26 PM
cutthroatxxx
Down hete now trying heat no luck yet.
Old May 18, 2012 | 06:35 PM
crazzywolfie's Avatar
crazzywolfie
have you been spraying it with pb blaster and tapping it with a hammer for the last couple of days. when i am working on something rusty i spray it with liquid wrench every day for about a week before i work on it.
Old May 18, 2012 | 08:04 PM
Breaker bar, long pipe, and some grunt.
Old May 18, 2012 | 08:17 PM
crazzywolfie
and pray you don't snap the head off the bolt..
Old May 18, 2012 | 08:31 PM
cutthroatxxx
No way to get to it with a breaker bar not enough room,I just got done painting it&went to put the leveling kit&bl on&while starting on the leveling kit I noticed the pass side shock nut on top was wayyyyy too small finally got it off&the threads were so screwd up from p.o. anyways...got to the bottom neither side will budge.Yes Ive been hitting it with pb all week,my air ratchet broke,my extension snapped...heated&heated nada,think Im gonna try an air hammer if that doesn't work than Ill cut the head off&drill it out.Ive beat on it for hours today.
Old May 18, 2012 | 08:55 PM
stewie01's Avatar
stewie01
Is it that rusty? Or just welded on?
Old May 18, 2012 | 09:01 PM
ramitt360's Avatar
ramitt360
I had a hell of a time with mine when i changed them all. I used freeze off, pb blaster and a plumbers torch and got them with that. Freeze off is good stuff, ever since then I use it on everything rusty.
Old May 18, 2012 | 09:28 PM
cutthroatxxx
I just went back down&tryd again to no avail,seems the p.o. used the hulk to put those bolts in.
