A/C Issues
Old May 22, 2012 | 09:46 AM
billcart's Avatar
billcart
When you replace a compressor you NEED to change out the orifice and the drier/accumulator. If the compressor failed there will be a collection of metal in the orifice tube and will contaminate your new compressor and cause all sorts of problems.
Old May 22, 2012 | 12:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1...
The only problem I have is , if the compressor is seizing, then why would it un seize after 5 minutes, makes no sense to me? If the compressor turns off after 5 minutes and the belt is squealing, the clutch is suspect. As is for the fact it's still low on 134a and the evap core is shot. I don't know what kind of tests the shop did. And without actually seeing it in person, it's very hard to figure out AC system probs.
Old May 22, 2012 | 09:40 PM
DODGEIT105's Avatar
DODGEIT105
Have the whole system flushed out. And replace the orifice and the drier as well. When a compressor goes bad it can send a bunch of debris throughout the system that is if it is not flushed will take out the new compressor and plug either the evaporator or the condensor or both for that matter. I know a guy who had a Kia that the compressor trashed the whole system. Basically the whole system was replaced except for the blower motor and switch. $1100.00 later his a/c worked. The stealer replaced just the compressor the first time and it trashed out in a day or so and filled the system up with debris.
Old May 23, 2012 | 03:38 PM
billcart's Avatar
billcart
All you have to say is KIA-Stealership...lol I will never own a KIA again. They offer a really long mileage/time warranty, because they will not do the work. The wife and I had one of those cars and after 8 miles the check engine light came on and luckily the car got stuck in flood waters (no one hurt)and the insurance company totaled it. That was at around 36k. The gas mileage was around 12 miles a gallon. It was a 2003 kia optima 4 banger. What a pos.
