My truck wont move in any gear! (stranded)
Old May 22, 2012 | 10:59 PM
  #21
gdstock's Avatar
gdstock
And behind that snap ring is an 800 pound gorilla......er.....spring. It ain't pretty when that gets away!
Old May 22, 2012 | 11:00 PM
  #22
Makes the overdrive unit come off easy....... Just don't be in the way.
Old May 22, 2012 | 11:03 PM
  #23
gdstock's Avatar
gdstock
Define "in the way." Do you mean same zip code?
Old May 22, 2012 | 11:04 PM
  #24
Pretty much any where behind the truck. Just not a good place to be. (and for a good distance at that......)
Old May 23, 2012 | 09:07 AM
  #25
Augiedoggy's Avatar
Augiedoggy
Originally Posted by zman17
I'm no transmission expert, but, from what Ive read here on DF, TC failure is pretty common. ?
it seems to be on these trucks... crappy stock converters I was told... mine exploded but It still drove., it just wouldnt shift right and would stall at stops a lot on the way to rebuild shop..
Old Jan 14, 2019 | 04:30 AM
  #26
Jason Keaster's Avatar
Jason Keaster
Default Check tourqe converter i have sim,prob.
Sorry to be the bearer of bad news, but if it smelled burned, it is burned. This means the frictions have burned up. If frictions are burned, it will be overhaul time.
Just to be sure, when you checked the fluid, did you check in Park or Neutral?
First thing when you get it home is to double check the linkage. Not likely, but good to check. These trannys usually start slipping pretty bad before they just give it up.
Drop the pan on trans and see waht is inside. There is a round donut magnet in the pan. The slimy goo on it is normal. If it has metal shavings on it - this is not normal and is not good.
Check and see, post photos as needed, and let us know what you find.
Les
​​​Less than a rebuild
Old Mar 31, 2022 | 09:28 PM
  #27
Hippo22jr's Avatar
Hippo22jr
OK. Part of the problem - you check the fluid in these in neutral with transmission at operating temperature.
It is not normal for them to just die. They usually start slipping, and usually still have reverse when forward gears quit. In fact, the trans usually goes into limp mode and will not shift up. Your problem is not typical. Check fluid as indiacted and let us know.
Also, there is a free download service manual and a parts manual in the FAQ/DIY section. It will be helpful to you. There are also a number of transmission related threads as well.
mine never slipped it just went out but it grabbed when it's cold or when it wants too
Old Apr 1, 2022 | 06:46 AM
  #28
Moparite's Avatar
Moparite
Might want to look at the date the thread was posted.
Old Apr 4, 2024 | 06:20 AM
  #29
fahad989's Avatar
fahad989
Dodge ram won't move in any gear ultimate guide. Read Here
