Truck runs like crap
Old May 22, 2012 | 06:26 PM
john91's Avatar
john91
Default Truck runs like crap
I have a 95 ram 1500 4x4 5.2. I bought it off a friend. He cut the cat out of the truck when he did the exhaust. Put the 02 sensor back in and everything. Well it runs like crap lately. It almost dies at idle and spits and sputters, makes a weird hissing noise so i replaced the IAC valve. Didnt fix it. Also going down the road itll bog and hold itself there till i bought have to floor it to get it to catch itself and go. Any ideas? Im slowly giving up on this truck. Thanks
Old May 22, 2012 | 07:11 PM
Matt Nickerson's Avatar
Matt Nickerson
Most likely related to this: https://dodgeforum.com/forum/2nd-gen...um-thread.html
Hissing? Under the hood or elsewhere? If under the hood, spray carb cleaner at all the vacuum lines around the intake manifold-replace as necessary...if that's the problem it'll likely fix most of the rough idle.
Old May 22, 2012 | 09:09 PM
john91's Avatar
john91
It is hissing like under the hood. Sounded like the iac valve hissing but i just replaced that after the first one did it. The old one was all gunked up and bad.
Old May 22, 2012 | 09:48 PM
gdstock's Avatar
gdstock
IAC is not a valve. It is a stepping motor. DId you celan the IAC port real good before installing a new one?
The hissing is vacuum. And a vacuum leak will make it run like crap.
Old May 22, 2012 | 10:28 PM
john91's Avatar
john91
Im not to familiar with the vacuum lines. It only hisses when it bogs down at idles and almost stalls out. Other than that the hissing is non existent. And I did not clean out the port I never thought of it. Would the catless pipe be a problem to? Just trying to eliminate possibilities here. Sorry for being a pain.
Old May 22, 2012 | 10:39 PM
No cat shouldn't be a problem. Not cleaning the throttle body would be though. The passage gets plugged up as well. There is a DIY in the faq section for cleaning the TB, try that first, see what happens. (be sure to disconnect the battery while you are doing it.)
Old May 22, 2012 | 10:57 PM
gdstock's Avatar
gdstock
Dang. I just posted that and more...or tried to post....must have clicked the wrong button....
+1 on HeyYou's info. Also, while you have the TB off, take a small mirror and flashlight and look down the throttle body into the intake. Pay particular attention to the rear on the pass side. See if there is oil pooling up there. If so, your plenum is blown and this may be s=the source of hissing and bogging.
Old May 22, 2012 | 11:41 PM
john91's Avatar
john91
I appreciate all the help on this one guys. I will clean the tb out tomorrow. Its almost midnight here haha but first thing on my list will be that. If not that i will check the plenum and see what happens. Hopefully it makes it better. This trucks giving me nightmares.
Old May 23, 2012 | 12:02 AM
gdstock's Avatar
gdstock
Check the plenum while you have the TB off to clean IAC port. Can't really see in there very well with TB in place.
Old May 23, 2012 | 04:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do not forget to disconnect the negative battery cable first, as HeyYou stated.
