Intermittant engine stumble
Old May 25, 2012 | 10:17 AM
96ramcj's Avatar
96ramcj
Default Intermittant engine stumble
I was going down the highway with my cruise set at 62 and the RPM's around 2700 when i suddenly started losing speed. the speedometer was slowly going down and when it got to 55 I stepped on the gas and the speed picked back up but the RPM's went up to 3600. The cruise was still on. It stayed like this for about a mile and then it kicked back in to normal. The check engine light did come on and I will get that read after work.
Has anybody seen anything like this before or have any ideas ? '96 1500
thanks,
Duane
Old May 25, 2012 | 10:54 AM
Darren270's Avatar
Darren270
2700 rpm at 62 mph? Yikes!
Old May 25, 2012 | 11:14 AM
Sounds like it dropped back into third. Wonder if TPS is failing.
Old May 25, 2012 | 02:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can check the codes yourself. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
