Shopping list (Water pump, timing chain)
Old May 27, 2012 | 10:34 AM
ZeroZero3's Avatar
ZeroZero3
Default Shopping list (Water pump, timing chain)
Hi guys, after my last post on my engine rattle sound I figured that while I am fixing that I might as well take a look at the timing chain and water pump. Since I live in a S$%? hole with very limited resources for parts and support I am looking for a part list of what I need to do the job.
So far I have, water pump and gasket, timing chain, sliders and gasket but I am not sure if the harmonic balancer and sprockets are required.
Thanks
ZZ3
Old May 27, 2012 | 10:42 AM
gdstock's Avatar
gdstock
Harmonic balancer should be fine. Use the right tool to pull it.
What sprocket are you asking about? If you go with a double roller timing set, the sprockets will be included. Check this SITE.
Don't forget coolant, oil change and filter. A torque wrench is recommended.
And what are sliders? Got me on that one also.
Old May 27, 2012 | 10:56 AM
ZeroZero3's Avatar
ZeroZero3
Forget about the sliders, that is my quad/MX 4 stroke engine background speaking.
I was refering to the crankshaft sprocket.
Old May 27, 2012 | 11:00 AM
Ham Bone's Avatar
Ham Bone
You'll need a 1 1/4 in socket to get the crank bolt out. Not sure if you have one of those. I had to hunt around for it
Old May 27, 2012 | 11:03 AM
gdstock's Avatar
gdstock
Sprockets are part of timing set.
Old May 27, 2012 | 11:07 AM
ZeroZero3's Avatar
ZeroZero3
Yes I have one, 32mm and a 30mm to, not cheap to buy indivudualy.
Good to know they are part of the kit.
Old May 27, 2012 | 11:16 AM
also want the bypass hose, and some hose clamps.... (goes from pump, to intake manifold. It hides under the A/C compressor.)
Old May 27, 2012 | 11:26 AM
stewie01's Avatar
stewie01
Not sure on the '99's but the harmonic balancer on my '01 requires a 3 jaw puller to get it off.
Old May 27, 2012 | 12:04 PM
gdstock's Avatar
gdstock
It is the same on a 99. Use the puller to pull the center hub. Do NOT pull from the outer part of balancer. It is held on by interference fit with a piece of rubber. If you pull this apart, you will have to get a new balancer. Use the bolt holes on the hub.
Old May 27, 2012 | 06:39 PM
ZeroZero3's Avatar
ZeroZero3
Thanks for the advice, how about the holes in the center, are they threaded?
