help
Old May 29, 2012 | 12:53 AM
Goatley's Avatar
Goatley
Default help
welp... I can get in my truck and it drive fine. However I can hit a bump and I get this weird vibration in the front end and I can come to a complete stop and it goes away. I dont have the slightest clue, but a local front end place said it could be a track bar?
Old May 29, 2012 | 07:21 AM
dhvaughan's Avatar
dhvaughan
that's called the death wobble.
i think? the most common cause is the track bar. check yours for loose/wear at the ball stud on the drivers side. its likely worn out. get a Moog replacement from rockauto for about $110-120. easy to change, search on here for tips and pictures.
if not track bar, it can also be ball joints, tie rod ends, etc. check for play. i'd expect your front end shop to be a little more sure. i'd also expect them to have checked all parts for play and have been able to zero in exactly on what's worn out... track bar wear out is very common.
Old Jun 1, 2012 | 11:37 AM
Goatley's Avatar
Goatley
I work at oreillys in my spare time and I get the moog piece for 56 bucks. Im slowly going to rebuild it as I can piece by piece.
Old Jun 1, 2012 | 11:45 AM
dnfd737's Avatar
dnfd737
My truck did that it was bad ball joints all 4
Old Jun 1, 2012 | 08:30 PM
dhvaughan's Avatar
dhvaughan
i've not replaced my ball joints yet, but the track bar is very easy.
some suggested jacking the body up higher to let the front axle hang, but i only jacked mine up a little and left the wheels on the ground so nothing would move.
https://dodgeforum.com/forum/2nd-gen...tall-tips.html
Old Jun 2, 2012 | 11:41 AM
Goatley's Avatar
Goatley
yea, theres a little play in the steering wheel also, but whats funny the first day with the new hub it was fine then the second day it started and progressed from there.
Old Jun 9, 2012 | 08:26 PM
Goatley's Avatar
Goatley
its gone now cant get it to vibrate
Old Jun 18, 2012 | 08:48 AM
Goatley's Avatar
Goatley
It just wont act up again! Maybe it was just mud in the mud or something?
Old Jun 18, 2012 | 09:15 AM
A bit of mud in a wheel will give you some strange vibrations.....
Old Jun 18, 2012 | 09:44 AM
Wombat Ranger's Avatar
Wombat Ranger
That's a good thing! Ba careful what you wish for
