My Performance Plan-What do you think?
Old May 31, 2012 | 10:40 PM
  #31
4HoNdaDODGE's Avatar
4HoNdaDODGE
I have the spectre with the k&n filter the quality in the filters is for sure noticable
Old May 31, 2012 | 11:03 PM
  #32
Ham Bone's Avatar
Ham Bone
You can mod your own throttle body into a 50mm for like 10 bucks worth of some bits.
Old May 31, 2012 | 11:59 PM
  #33
SilverSS's Avatar
SilverSS
You may want to look into 4.10 or 4.56 gears depending on what you have now and what size tires you plan on running.
Old Jun 1, 2012 | 04:32 PM
  #34
Big Joe C's Avatar
Big Joe C
Well I'm staying with stock tire size (16s), may go stock 17s but thats it. I'm gonna be doing any hardcore offroading or mudding either. So I think stock gears are good for now. Also are our trucks posi?
Old Jun 1, 2012 | 04:40 PM
  #35
stewie01's Avatar
stewie01
I believe that "posi" is a GM term.
I think it's Anti-Spin Differential on our trucks. And it depends on the option's from the factory, if it's 4x4 chance's are it's got a LSD rear end, if it's 4x2 I'll bet it's an open diff but you can either 1. Get a build sheet from Chrysler, will have all the option's for your truck, 2. Check the sticker in the glove box (if it's still there, if there's NO mention to LSD or Anti-Spin then you have an open diff) or 3. They put sticker's on the axle itself, chance's are it's gone but you can give it a look too.
I went from 16"s to 17"s but choose what I found to be the normal stock tire size for a 17" wheel...
And even if your truck has an open diff it IS possible to spin both tire's.
Old Jun 1, 2012 | 06:44 PM
  #36
Jigabop's Avatar
Jigabop
here's a good way to test it: jack up the rear end till the tires are off the ground, put it in gear so the tires start spinning, and if only 1 side is spinning, or both sides are spinning in opposite directions, its open diff...if both sides are spinning in same direction but you can stop one of the tires by hand (with a 2x4 or something), its also open diff...
if both tires spin the same direction and you can't stop or slow down either rear tire, its limited slip.
Old Jun 1, 2012 | 06:48 PM
  #37
It would be easier, and safer..... to block the front wheels, put the truck in neutral, jack up the rear, and spin one of the rear tires by hand. If the other side turns the same way, you have a limited slip, if it turns the opposite direction, you have an open rear. (or, a worn out LSD....)
Old Jun 1, 2012 | 06:57 PM
  #38
Jigabop's Avatar
Jigabop
wheres the fun in that?!!
Old Jun 1, 2012 | 07:08 PM
  #39
Agh... Details, details.
Old Jun 2, 2012 | 08:51 AM
  #40
Big Joe C's Avatar
Big Joe C
Ok HeyYou I'm trying your way and I get back to you on it.
