Fixed Plenum Now Need to Replace Fuel Rail
Old May 30, 2012 | 04:31 PM
sbrodacz's Avatar
sbrodacz
I cannot find anyone that has one.
Old May 30, 2012 | 06:29 PM
I may have one....... Plastic, female fitting with some funky clamp on it.... I can prolly post a pic in a bit.
Old May 30, 2012 | 08:08 PM
sbrodacz's Avatar
sbrodacz
OMG yes! That sounds just like it. the clamp has 2 yellow fitting thingy on it that lock it close.
Old May 30, 2012 | 08:26 PM
sbrodacz's Avatar
sbrodacz
I'll try and get better pictures.
Old May 30, 2012 | 08:29 PM
sbrodacz's Avatar
sbrodacz
You can see in the middle. There is a hole. That is where the fitting was.
Old May 30, 2012 | 08:43 PM
Wombat Ranger's Avatar
Wombat Ranger
Plastic engine parts. Brilliant.
Old May 30, 2012 | 09:03 PM
CPTAFW163's Avatar
CPTAFW163
Too bad it is not a steel one. I have an extra steel one that I painted black wrinkle. Came off my 1996.
When you need to take off the fuel line you MUST PUSH THE LINE INTO THE RAIL then you push the quick disconnect in and slide the rail and disconnect out at once. If you JUST push the quick disconnect in without pushing the fuel line into the rail, then you will fight to no avail to get it off.
Old May 30, 2012 | 09:46 PM
Yep, I have one of those. PM me, and we can make arrangements to get it to you. It won't fit my 96. I have to work in the morning tomorrow.......
Old Jun 2, 2012 | 09:26 PM
sbrodacz's Avatar
sbrodacz
Problem number two. I got a "new" rail put on this afternoon but it is leaking. It is squirting fuel out from the end. It looks like it's a pin size hole. Is there anything I can put on the rail to stop the leak or do I have to find another one and reinstall it? Don't forget it is the plastic fuel rail....
Old Jun 2, 2012 | 09:37 PM
nate_9ers's Avatar
nate_9ers
It is pressurized so it maybe tough to fill that hole
