Pulling my 360, for dummies
Old Jun 7, 2012 | 02:49 AM
Moochoff's Avatar
Moochoff
Question Pulling my 360, for dummies
So is it easier to pull with tranny attached or separate them before hand?
What needs to come out for it to clear minus the radiator, fuel lines, and starter? How much benefit for taking the hood off?
Getting everything ready to order up soon
Old Jun 7, 2012 | 08:11 AM
Lone136's Avatar
Lone136
In the past I have always removed the hood so the engine is able to be removed right out of the engine bay. Unbolt the motor from the trans and remove
Old Jun 7, 2012 | 08:38 AM
mccart's Avatar
mccart
Grille, radiator, ac condenser...anything in front of the motor. Then unbolt it from the trans and yank it out. I've never pulled the hood and never had any problems
Old Jun 7, 2012 | 09:33 AM
3dubs's Avatar
3dubs
Taking the hood off always makes it easier to work on you truck. Pulling the engine if you don't take it off you will damage it. When in doubt take it off. I am no expert but have pulled a few engines. Every time I say I think it will clear something get bent or broke. It causes headaches and costs money. Get everything out of the way. Be sure to mark your hood so it lines up right when you get it back on.
Old Jun 7, 2012 | 10:10 AM
I always pull the hood to remove an engine. It's a lot easier than yanking everything in front. On trucks with lift, I also let all the air out of the front tires, to lower it some. Pull JUST the motor, leave the trans in the truck. (watch out for the crank sensor though, might wanna pull that before you yank the motor.)
Old Jun 8, 2012 | 11:31 AM
kadetklapp's Avatar
kadetklapp
Tagged. This is something I'm going to face soon.
Old Jun 8, 2012 | 02:32 PM
Moochoff's Avatar
Moochoff
Thanks fellas... You can be sure Ill be posting a ton of questions when I get her started, and hopefully reciprocate the useful info to others when I'm done!
Old Jul 6, 2012 | 10:23 PM
Moochoff's Avatar
Moochoff
So guys, any trick to separating the transmission from the engine? Will the torque converter fall out if Im not careful?
As always- THANKS
Old Jul 6, 2012 | 10:29 PM
If you are pulling the motor, support the trans. If you just let it flop, the t/c will indeed leap off.... (makes a mess, don't ask how I know this.....) Once the engine is out of the way, I just use a length of chain, and a couple bolts to keep the trans from flopping down. Gotta be creative in finding a place to secure things, so that ya don't break anything, and the chain will keep the trans up.
Old Jul 7, 2012 | 01:17 AM
gdstock's Avatar
gdstock
I cut a 1x4 and drilled two holes to insert bolts to hold TC.....when I was dropping and reinstalling tranny (a couple of times....because it was so fun!) But that ora chain is a good idea. Dropping it out of there can cause damage, as well as the above referenced mess! Gotta block up front of tranny when you get it loose.
