need some help
Old Jun 13, 2012 | 01:39 AM
cutthroatxxx's Avatar
cutthroatxxx
Default need some help
Ok here's the deal&some background info.I've been working on my truck a little bit@a time for a month .Only real problem I had was for those of you who've read older posts of mine,know that around maybe 50 trucks shakes a little bit not much.I also sometimes get code 37 well I did plugs&wires&since its been sitting I've gutted the cat&tomorrow doing the valve covers because I've noticed a leak&I'm gonna be replacing the cap&rotor.That being said I don't know if the shaking has went away since everything I have already fixed or if it was maybe in the wheels.
So I'm just to be safe going to do a compression test&if all is fine there should I replace the tcc solenoid while I'm getting the alignment?My friends mom told me when I take it to the shop she will pay for whatever needs fixing.Just don't wanna throw parts@it that don't need it.I also replaced a tie rod sleeve the outer tie rods seem fine what else in the suspension should I look for?I'm gonna check ball joints also.P.s. the code only comes on once in a great while&nope don't have tow package.I'm wondering if maybe trac barbis bad?Ill check that also.Any other ideas?
Old Jun 13, 2012 | 01:44 AM
cutthroatxxx
Default guys with 94s&95s answer this
Edit..............
Old Jun 13, 2012 | 07:45 AM
If you have a trans temp sensor, it will be on the cooler line, very close to the trans. (the one toward the front of the trans I believe.)
Check the connections at the PCM for the TCC circuit. I think trans solenoids have a common power source, and PCM just grounds the solenoids to engage them. Is your trans shifting into O/D, and TCC locking correctly? If you have a lot of miles on the truck.... it sure won't hurt anything to replace the solenoids.
Old Jun 13, 2012 | 11:50 PM
cutthroatxxx
Thank ya Ill get to it&keep ya posted but yup seems to lock up as should
Old Jun 14, 2012 | 12:02 AM
gdstock's Avatar
gdstock
donthavea94or95butif tclocks upfinethenitisprobablyok.howmany mileson tranny?may wanto check fluidorchangeif ithas beenawhielsinceit hasbeen done.
Old Jun 14, 2012 | 10:03 AM
Space bar broken?
Old Jun 14, 2012 | 02:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Holy crap GD,
Old Jun 14, 2012 | 06:23 PM
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by zman17
Holy crap GD,
+1 to THAT!
Old Jun 14, 2012 | 06:31 PM
stewie01's Avatar
stewie01
Hopped up on pain pills again are we?
Old Jun 14, 2012 | 07:39 PM
redneck_ram's Avatar
redneck_ram
GD i think you need to lay off the painting of the truck for awhile, i think the paint thinner is getting to you!
