95 ram randomly dies, but starts right back up
Old Jun 14, 2012 | 01:00 AM
gdstock's Avatar
gdstock
If the ground is one that is needed for some of the sensors or the PCM, that is where the problem would be. The ground to the lights can be fine - they all ground to fender or frame.
Old Jun 16, 2012 | 05:58 PM
r341jag's Avatar
r341jag
Thanks guys for all your help. I cleaned the grounds (which I found the ground wire by the alternator was loose) and also changed out the ASD relay, which the old one was nasty looking. So far two days and no problems so I hope it continues to run fine. If it doesn't, next will be the crank sensor (which I found with the lift, looks accessible through the fender well above the frame, looks like pretty clear shot). Thanks again for everyones help
Old Jun 16, 2012 | 06:18 PM
Good Luck!
Old Jul 18, 2012 | 10:28 PM
r341jag's Avatar
r341jag
Thanks guys for all your help, finally got around to doing it, and sure enough there was so much oil and dirt on the sensor that I dunno how it read anything. Wouldve been a quick job, but didn't figure out the trick of going through the wheel well with the splash guard removed until about 2 hrs after cussing at the truck and the space. After that took about 15mins with me and a buddy working on it. One on top and the other from under the truck. That is definitely the trick for any of you out there gonna try and tackle this.
Old Feb 19, 2014 | 11:36 AM
freenick's Avatar
freenick
my 96 dodge ram van does the same thing, what kind of crank censer should I get and where?
Old Feb 19, 2014 | 11:37 AM
freenick's Avatar
freenick
should I get it at the dealer
Old Feb 19, 2014 | 11:50 AM
Some of the aftermarket sensors don't preform well in our engines. Dealer part is the best bet.
Old Feb 19, 2014 | 12:35 PM
xjarhead69's Avatar
xjarhead69
I had all kinds of issues with a Napa crank sensor.
Dealer only.
Dave
