Plenum - my turn
Old Jun 19, 2012 | 11:30 AM
lastrights's Avatar
lastrights
I had ngk v powers and iridium ix and didn't like either of them . My truck responds great to autoligjt 3923
Old Jun 19, 2012 | 12:24 PM
tbone360's Avatar
tbone360
I guess it depends on your truck. My truck likes ngk.
Old Jun 19, 2012 | 06:17 PM
mcweaver's Avatar
mcweaver
here's my update, everything was going good I had everything scraped, cleaned and ready to put back together. Last thing I wanted to do was chase the threads with a tap (knew I shouldn't have) and you guessed it on the last hole snapped the tap down in the hole. So now in the morning I have to go chase down the snap-on man and hope the tap extractor works! If not I'm not sure what to do, not enough to grab a hold of and don't want to take the heads off...
Old Jun 19, 2012 | 06:24 PM
Use a sharp HARD punch, and a big *** hammer, and shatter the tap. (cover the valley, so you don't get chunkys in there......)
Old Jun 19, 2012 | 06:28 PM
mcweaver's Avatar
mcweaver
Then after that get a new tap and re chase them as i'm assuming shattering the tap could mess up the threads? This would also only be a last ditch effort and looking to stay away from taking off the head?
Old Jun 19, 2012 | 06:33 PM
Taps are extremely hard, but, very brittle. (sounds like a contradiction doesn't it?) They actually shatter fairly easily, and then you can just pick the pieces out of the hole, if they don't just fall out. (the end holes are open to the air anyway. won't drop anything INTO the motor.) If you can't get the right tool for the job, shattering is fairly easy. I would just run another bolt down the hole, to make sure the threads survived. I don't usually bung 'em up when busting out a tap.
Old Jun 20, 2012 | 03:05 PM
mcweaver's Avatar
mcweaver
so I got my hands on a Tap Extractor from the Snap On man and it worked just like it was supposed to! Now if i can just remember where all these bolts go, hopefully it will be up and running tonight just in time to do a hub asembly...
Old Jun 20, 2012 | 08:04 PM
mcweaver's Avatar
mcweaver
I've got everything together and am on one of the last things, putting the alternator back on. Well apparently I have misplaced one of the small nuts on the back. So yes $.05 is keeping me from getting my truck going....
Old Jun 20, 2012 | 08:20 PM
lastrights's Avatar
lastrights
Congrats on the progress , when I removed my plenum I found a broken bolt from previous owner . I just left it no problems
Old Jun 26, 2012 | 06:42 PM
mcweaver's Avatar
mcweaver
Default update
after getting everything back together, i had a water leak, my truck wouldn't idle, truck played games shifting from 1-2, 2-3 and the wonderful people at Autozone told me I had a vacuum issue. So after taking everything back apart and looking at things again and thinking I fixed the problem, well I didn't. So frustrated I took it to our garage very discouraged and embarassed. So the no idle, I forgot to plug in the IAC, water leak was a wore out spring clamp on the upper radiator hose, the no shifting the TV cable was just too tight and caught on something. Anyhow, even though this makes me look a little more like an idiot I wanted to post this update because I'm guessing somewhere down the line someone else will have one of these problems.
