use old motors in newer rams?
Old Jun 19, 2012 | 02:53 AM
kaoskelly's Avatar
kaoskelly
Default use old motors in newer rams?
i am attempting putting a nice 76 360 i have in my 95 ram,the ram is mint came with 318 auto 4x4 short box,this truck will be run strickly on propane! the questions i have is,is there a way to use the crank sensor for the computer,there is no provision 4 it on the block! also the belts i have figured out but can i adjust the computer for the new combo or get an aftermarket one,i am lifting the truck and putting 1 ton axles on it so it will be modded out already,any input on someone doing this type of build would be awesome!
Old Jun 19, 2012 | 03:05 AM
merc225hp's Avatar
merc225hp
I need more info about what propane system you are going to use, injected or evap and mixer?
Welcome to DF
Old Jun 19, 2012 | 03:45 AM
kaoskelly's Avatar
kaoskelly
i have an older dual evap that i like.
Old Jun 19, 2012 | 04:12 AM
merc225hp's Avatar
merc225hp
Ez answer then "no" pcm at all for the ign side of the motor, use after market dizzy and ign box for the LA motor. A fast timing curve is needed for a propane motor, they also like big compression numbers as well. Do it right and you can make some big hp on propane.
Edit: Have you tried bolting on the Magnum motor mounts to the old LA block?
Pentickton? in BC down south?
Old Jun 19, 2012 | 04:52 AM
kaoskelly's Avatar
kaoskelly
motor mounts ,last thing i havnt looked at,and wich transmission transfer case to use,i am still in the air about.
Old Jun 19, 2012 | 01:18 PM
merc225hp's Avatar
merc225hp
Tranny and t case, Well 46rh is what's in your truck and as far as I know no pcm to control it, so you might be able to use the org one in the truck. I am not a tranny expert by any means so I hope someone with more exp will chime in here to help you on that.
Old Jun 19, 2012 | 04:52 PM
Sooper's Avatar
Sooper
Years ago I put a 360 from a 1997 Grand Cherokee in a 1978 D100 that originally had a Slant 6. Dodge was good about keeping things interchangeable. I went from the Slant 6 to an LA 360, and then up to a Magnum 360, and the mounts and TF727 worked with both generations of the 360. The motor mounts should not be an issue for you.
Old Jun 19, 2012 | 05:03 PM
crazzywolfie's Avatar
crazzywolfie
if you got the money you will be able to stick a la 360 in it but i am pretty sure the motor mounts are difference and you may be loosing power.
Old Jun 19, 2012 | 05:09 PM
kaoskelly's Avatar
kaoskelly
another question i have is should i take a 727 and try to adapt the overdrive still using the 231,or just use the 46 rh with a better torque converter,and also seems i have a distributer already curved and a msd box for propane,will i have any issues with the charging system using the origanal computer for everything else on the truck other than ignition? thanx guys i really apriciate the feedback
Old Jun 19, 2012 | 05:13 PM
kaoskelly's Avatar
kaoskelly
just another quick reply i am going with this motor,i have broken it in with 10 000 kms in my old power wagon and am very happy with this tough motor,its basicly va muscle car motor with all tghge parts i put in,so no i wont use a newer 360 i am a fan of old mopar motors i have bagged on them for ever and they never die,just so you know that im not looking for a 5.6 or anything,thanx
