Tranny running hot
Old Jun 21, 2012 | 11:11 PM
gdstock's Avatar
gdstock
I buy from HERE. Good pricing, (plenty of profit margin for me selling locally to support my habit a little) and free shipping.
Old Jun 22, 2012 | 12:19 PM
BamaRam97's Avatar
BamaRam97
This is the only other option I've found for inline transmission sensor.
http://www.summitracing.com/parts/ATM-2286/
could you just make one from fittings at Lowe's/Home Depot? It is just a basic 3/8 T compression fitting. I would think that maybe cheaper.
Old Jun 22, 2012 | 01:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by QuadCabLuv
is it just me or has diesel manor lost their minds? I knew that the fitting was about $30 but then they want almost $14 for shipping. It will fit in a envelope for gods sake. The smallest flate rate box at USPS has 8x the room it would need and those are $5 shipped.
Live with it dude. It's the best way to go, simple as that.
Sure you can, but it will cost the same or more, and will restrict flow, and/or the tip of the sensor will be out of the fluid too far for a good reading.
Old Jun 22, 2012 | 02:28 PM
QuadCabLuv's Avatar
QuadCabLuv
Funny that you recommended them. I actually already had them on my watchlist from that same exact buyer. I went ahead and ordered them this morning, i just hope that my tranny will keep from grenading. Hit 210 today for a sec and i shut it off. Im really hoping that a fluid change filter and the govenor and selonoid fix the issue. Im wonderin about adding a trans oil pressure gauge.
Old Jun 22, 2012 | 10:58 PM
QuadCabLuv's Avatar
QuadCabLuv
ahhah i found another option for a line manifold. this one will allow for a second sensor to run my psi gauge.
http://www.ebay.com/itm/250648706522...84.m1439.l2649
Old Jun 22, 2012 | 11:02 PM
That's kinda neat. Good find!
Old Jun 22, 2012 | 11:03 PM
QuadCabLuv's Avatar
QuadCabLuv
if i get a pressure gauge how high does it need to read? Ive noticed that most regular oil pressure gauges stop at 100-150 psi but there are a few transmission oil pressure specific gauges that all go to 300 psi? do our transmissions ever see that much pressure?
Old Jun 22, 2012 | 11:34 PM
gdstock's Avatar
gdstock
Pressures will vary based on rpm and gear as well as what port you put it in. Pressure on colling line will be very low, and is not an indiactor of anything happening inside tranny.
Old Jun 23, 2012 | 08:59 AM
QuadCabLuv's Avatar
QuadCabLuv
well dang. that blows my idea out of the water. What am i going to use that second sensor port for now. lol. i guess ill just plug it.
Old Jun 23, 2012 | 12:52 PM
zman17's Avatar
zman17
After you buy all the adapters and double flare tools to install that $19 hunk of metal in the line, you'll spend the same or more money and a lot more time installing. Good luck, hope it works out for you.
