What is missing?
Old Jun 21, 2012 | 09:09 PM
ITTTom's Avatar
ITTTom
Question What is missing?
So I crawl under the truck and look to see what I am in store for when look to replace my Oil Pressure Sensor and I about lost it (or in this case already did).
Can someone tell me what should be in this threaded opening that I am apperently missing?
1996 / 318 / Automatic / 4x4 / 1500 / Originally had all the bells and whistles...
This is a location shot from the rear of course
And this is the upclose (Well as close as I could get in focus)
Any Ideas?
Old Jun 21, 2012 | 09:49 PM
Gord.'s Avatar
Gord.
That's the port for the egr, which i believe they started eliminating in 96. From what i've heard, they just used a block off plate on the old style manifold until they redesigned it. The block off plate should be just around the corner from where the picture shows, an top of the back of the manifold.
Gord.
Old Jun 21, 2012 | 10:04 PM
ITTTom's Avatar
ITTTom
I did find the block off plate on the top end, and thanks for the info.
Old Jun 21, 2012 | 10:22 PM
Gord.'s Avatar
Gord.
No problem, I made a block off plate for my 95 when i fixed the plenum, the egr was clogged up anyways.
Gord.
Old Jun 21, 2012 | 10:24 PM
Does it set EGR codes often?
Old Jun 21, 2012 | 10:26 PM
Gord.'s Avatar
Gord.
Yep, mine throws a code for taking too long to warm up.
Gord.
Old Jun 21, 2012 | 10:27 PM
But not for the EGR??? What temp stat you got in your truck?
Old Jun 21, 2012 | 10:32 PM
Gord.'s Avatar
Gord.
Stock temp, so 195? The last time I checked the codes I believe that was the only code, and the CEL takes a minute or two to come on after I start the truck so i assume it's still the same.
Gord.
Old Jun 22, 2012 | 11:09 AM
Think you got a bad stat there in that case.
(sorry 'bout the thread-jack.....)
Old Jun 22, 2012 | 11:38 AM
Wombat Ranger's Avatar
Wombat Ranger
Gord.
More thread jacking... What did you do with the vacuum lines and exhaust manifold port? On second thought, you whould really consider doing a DIY on this, as many people ask about the delete.
