gas tank problem
Old Jun 23, 2012 | 01:38 PM
motorboatinjesus's Avatar
motorboatinjesus
Default gas tank problem
Hey guys, so yesterday at fill up when the pump clicked off there were some noises being made and i knew something was wrong under there, anyway after about 3-4 seconds a bunch of gas spilled out from the passenger side of the gas tank onto the ground. The leak stopped however, and i was shaking my truck and nothing was coming out. i couldnt see where the leak was because the metal guard on the side. I drove it home and noticed a gas smell quite strong when i got out, but couldnt see any gas dripping. On a side note i am planning on taking the bed off this weekend to pull the pump sender because the fuel gauge has been going crazy. Has anyone experienced this problem?
Old Jun 23, 2012 | 01:42 PM
The tank is plastic... so, have a look at it while its out. Should be pretty obvious where the gas is coming from. Probably sloshing right out the seal for the pump anyway.....
Old Jun 23, 2012 | 01:51 PM
motorboatinjesus
There was a shield on the side of the tank and the gas coming out in between the shield and tank.. i only looked for a second excuse me if im wrong. But yea that is what i was thinking
Old Jun 23, 2012 | 01:54 PM
Yeah, shield is thin steel. Just protects the side of the tank from crap the drive shaft might throw. (but, not from the drive shaft itself, should it decide to let go.....) If gas is running out the top somewhere, that's where it would show up at.
Old Jun 23, 2012 | 01:57 PM
motorboatinjesus
Alright thanks for the help ill tackle it today
Old Jun 23, 2012 | 02:00 PM
If it's toward the back..... also check where the pin that holds the shield in place pokes into the tank..... ('bout half way down the side of the tank, well toward the back.)
Old Jun 23, 2012 | 02:05 PM
motorboatinjesus
Okay im going to go look at it right now. Another question though, i just phoned my parts dealer in town (napa) and they want 400$ for the pump assembly! If my sender is going bad from what I have read i have to replace the whole thing?
Old Jun 23, 2012 | 02:39 PM
gertie240's Avatar
gertie240
thats kinda high isnt it? try rock auto, you can get 5 percent off with the coupon code.
Old Jun 23, 2012 | 02:53 PM
Yeah, 400 is way over the top. Unless you are in Canada.... or elsewhere outside the US. Should be between 2 and 3 hundred. Go with Delphi, or Denso... stay away from airtex.
Old Jun 23, 2012 | 03:02 PM
motorboatinjesus
Yes i am in canada, its unfortunate. I will try rock auto. Also, i started my truck and drove it back and forth, got out and could smell gas. I looked everywhere and its not dripping. I cant find the leak!
