I hate oil leaks&what is this called?
Old 07-05-2012, 05:41 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by cutthroatxxx
sorry been busy,anyways I plan on getting to this Saturday or Sunday,anyways when I do the fad does anything pull out with it when I undo the 4 bolts?Can't find much on it&tip you guys were right about bolts wanting to break.I called shop to see about them doing it&they said we just did one&had two bolts break!Also do I need to add any fluid when I do it?The leak is a pretty good one
Dude, get a damn Haynes manual. You'll know how to check the front diff (and rear for that matter) to know if you need to add/or check fluid level. As far as the CAD goes, read this link. There is a pretty good pic of the unit also. http://www.dodgeram.org/tech/repair/..._engagment.htm
ANd if you are going to keep "calling" shops to do the work, why are you asking questions here? Nothing will **** a shop off more , than someone that is telling them what to do.
Old 05-19-2013, 06:50 PM
joshram1500's Avatar
joshram1500
joshram1500 is offline
Default CAD gasket
My CAD is leaking pretty bad but the 4x4 actuator is still working. Does anyone know where I can get just the gasket without buying the whole actuator to save some money?? Thanks
Old 05-20-2013, 05:09 PM
zman17's Avatar
zman17
zman17 is offline
Try quad4x4.com
Quick Reply: I hate oil leaks&what is this called?
