I hate oil leaks&what is this called?
Old 06-28-2012, 12:38 AM
cutthroatxxx's Avatar
cutthroatxxx
cutthroatxxx is offline
Default I hate oil leaks&what is this called?
Ok so I noticed I had a small oil leak so degreassed&cleaned everything up real good&saw oil leaking from the bottom hose that goes into power steering pump& looks like its coming from where it screws in.Figure Ill trybto tighten tomorrow also on pass side front axle theres some kind of vacumm actuator with a plate that bolts to axle &looks like it just bolts on&there's a seal there that has a small leak...what is it&how do I fix it?Any ideas id appreciate it
Old 06-28-2012, 12:49 AM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Thats the CAD... they are pretty simple to remove. If your unsure just do a quick search and i think theres a link about removal on here somewhere
Old 06-28-2012, 08:37 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,285 Likes on 3,032 Posts
CAD is only held on by four bolts. Keep in mind, they like to break.....
Old 06-28-2012, 08:15 PM
cutthroatxxx
So does the fad leak motor oil?
Old 06-28-2012, 08:43 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
No. If your seeing motor oil its coming from the motor. Take a close look at the pan and valve covers for any leaks
Old 06-29-2012, 06:39 PM
cutthroatxxx
Can't find it
Old 06-29-2012, 06:52 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
If its motor oil your seeing it isnt coming from the cad. Like HeyYou said its the matter of 4 bolts to remove it. If you are going to attempt to remove it I would be soaking the bolts in some sort of chemicals for a day or 2
Old 06-30-2012, 12:06 AM
DK-v1's Avatar
DK-v1
DK-v1 is offline
If your power steering hose is leaking (especially the high pressure hose), it will literally spray fluid everywhere.
Get someone to turn the steering wheel all the way to one side while you look to see where the fluid is actually coming out at. Once you fix that, then go after the 'oil' leak.
Old 07-04-2012, 07:40 PM
cutthroatxxx
sorry been busy,anyways I plan on getting to this Saturday or Sunday,anyways when I do the fad does anything pull out with it when I undo the 4 bolts?Can't find much on it&tip you guys were right about bolts wanting to break.I called shop to see about them doing it&they said we just did one&had two bolts break!Also do I need to add any fluid when I do it?The leak is a pretty good one
Old 07-05-2012, 12:04 PM
billcart's Avatar
billcart
billcart is offline
It's not a fad it's CAD = Center Axle Disconnect. Go to the dealership and get the cad servo and it has a new gasket, bots and clips for the fork. The part will cost around 185. A much better price than the shop would charge you. Download the service manual from the DIY section for your year. Just a piece of advice though, if you do break a bolt taking it out take the rest out, pry off the cover little by little on all sides until it comes out. Get a good pair of vice grips and clamp down on those broken bolts and they should come out no problem.
Quick Reply: I hate oil leaks&what is this called?
