Holley Throttle body and MOPAR perf single plane intake
Old Jun 28, 2012 | 03:35 PM
1999 ramDan's Avatar
1999 ramDan
Default Holley Throttle body and MOPAR perf single plane intake
Hello Everyone,
I have been doing a lot of searching lately and haven't been able to find much information on this topic. We all know the wonderful stock intake has plenum pan issues, and I figured, if I'm going to be taking my truck apart to fix it (again) why not consider an upgrade? I was on summit racing and found this intake and throttle body.
I was thinking of adding a CAI and headers to the mix, try to liven up the little 318. However, I am hesitant to make such a purchase because I don't know what other people have experienced out there with either the intake of the throttle body. Would this be a wise move? I'm not looking for a street racer here, just something to bring some more guts to the 5.2. Its a 5 speed, reg cab, 4x4 if anyone needs to know that. Thanks for your time and knowledge!
Old Jun 28, 2012 | 05:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That intake is fine as long as you install a lower gear ratio. You'll lose more bottom end with that intake and the 3:55 gears you have currently.
Old Jun 28, 2012 | 07:29 PM
mccart's Avatar
mccart
I'd do gears instead, they'll bring more out than the intake and tb. Definitely in the low end and as zman said you'll lose a lot of low end with the intake. Unless you compliment it with 1.7 roller rockers or a cam I'd go with re-gearing to 4.10
Old Jun 28, 2012 | 09:03 PM
Wombat Ranger's Avatar
Wombat Ranger
^^^ Or even lower gearing if you are gonna run bigger tires at all.
Old Jun 28, 2012 | 11:47 PM
lastrights's Avatar
lastrights
I like the airgap I wish I did gears OT is a good mod to get it up and go , with Sct and 1.7 and fastman I didn't Notice any lose of power or low end
Old Jun 29, 2012 | 09:35 AM
1999 ramDan
Hello Everyone,
I currently have 3.73 gears in the truck. Also, the main reason I was asking about the intake and throttle body was because I need to take it apart anyway to do the plenum gasket. Has anyone had any experience with the TB? I do plan on upgrading to a 285/70 17 tire this fall. Thank you everyone for all your input!
Old Jun 29, 2012 | 04:44 PM
zman17's Avatar
zman17
"Has anyone had any experience with the TB?" What does that mean? And what does it matter? Taller tires need gears, simple as that.
Old Jun 29, 2012 | 07:07 PM
mccart's Avatar
mccart
I'd just stick with the stock
Manifold and tb. Get the gears. I have a 318 with 3.55s, 285/75/16s and it SUCKS
Old Jun 29, 2012 | 07:15 PM
Lone136's Avatar
Lone136
I went the way of gears 456 1.7 Harland sharp roller rocks and a SCT from Hemifever. I also have 35's on my truck. I do have a Mopar M1 intake for my 318, but at this point I don't see me installing it on this truck. I need to put it on Ebay
Old Jun 29, 2012 | 10:43 PM
Whaddaya want for the manifold?
