Gas in intake manifold
Old 07-05-2012, 11:07 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
I highly recommend getting the ones with the all plastic body as opposed to the metal body. The metal body absorbs a lot of heat where the plastic body does not.
'92-'99 EV1 style - http://www.ebay.com/itm/8-BOSCH-19LB...6b948b&vxp=mtr
'00 + EV6 style - http://www.ebay.com/itm/Ford-Motorsp...12a4a0&vxp=mtr
  #32
Old 07-06-2012, 07:28 AM
Sooper's Avatar
Sooper
Sooper is offline
I'm guessing, if for a '92 - '99, one would need to cut off the stock injector plugs, source the later model plugs, and splice them in place?
  #33
Old 07-06-2012, 08:13 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
Not if you use the injectors with the EV1 rectangular shaped connector. It's a very simple unplug and remove the old and install and plug in the new.
  #34
Old 07-06-2012, 08:51 AM
Sooper's Avatar
Sooper
Sooper is offline
So both EV1 and EV6 come in both plastic and metal bodies?
  #35
Old 07-06-2012, 08:57 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
Some of the EV1 come with the metal but all the EV6 are plastic.
  #36
Old 08-11-2012, 05:54 PM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
@bwdakrt, Do you have any other links for injectors like the ones you previously linked to?
  #37
Old 08-11-2012, 06:41 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
Do a search on ebay for 'Ford 19# fuel injector' and you'll find plenty of them.
  #38
Old 08-11-2012, 07:03 PM
jeffrey.hughes4's Avatar
jeffrey.hughes4
jeffrey.hughes4 is offline
Ooops! Posted in the wrong spot...withdrawn.
  #39
Old 08-11-2012, 07:25 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
so would these work
also i noticed on the other ebay link you posted that under application they had 90-93 Trk/Van 5.2 5.9 V8. would that mean that my 93 would most likely already have something similar just a bit older and bigger? only reason i ask is i wouldn't mind upgrading if my 93 would start better and get even better gas mileage. right now it starts ok but compared to my 81 it is slow.
  #40
Old 08-11-2012, 08:17 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
so would these work
Those will work just fine.
Quick Reply: Gas in intake manifold
