ac compressor
Old Jul 3, 2012 | 03:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes unplug it . And jump the plug itself.
Old Jul 3, 2012 | 03:30 PM
gdstock's Avatar
gdstock
..........................AND.......... .........
Old Jul 3, 2012 | 07:28 PM
rjs111's Avatar
rjs111
so ...I put power to the ac clutch and NO response..can I assume the clutch went bad?
Old Jul 3, 2012 | 08:00 PM
wpnzrule's Avatar
wpnzrule
Mine is doing this also. Runs for about 15 minutes then shuts off and wont come back on. I have jumped the switches and have made sure I am not building too much high side pressure. From what I can tell through trouble shooting and researching,the ac compressor has some type of temperature cut off for when it gets to hot to keep from burning up the clutch. I am replacing the compressor on mine tomorrow, I picked up a working pull-off compressor for $75. I will let you know what happens. Hope this helps
Old Jul 3, 2012 | 08:41 PM
measure resistance across the clutch when it stops working. Verify you still have voltage and ground at the connector.
Old Jul 3, 2012 | 08:50 PM
gdstock's Avatar
gdstock
Make sure you pull a vacuum on the system before filling.....
Old Jul 4, 2012 | 01:09 AM
rjs111's Avatar
rjs111
I have NO ground at the connector-
Old Jul 4, 2012 | 01:13 AM
gdstock's Avatar
gdstock
Do you have 12v on the black wire with blue stripe?
Old Jul 4, 2012 | 08:57 AM
Black wire with white trace is ground. It should ALWAYS be grounded. Wire goes from compressor connector, to Splice 122, (unfortunately, back of motor, just to the passenger side of distributor.) from there to Ground 105. (at the power steering unit, front of engine.)
Old Jul 4, 2012 | 12:20 PM
ReadRam's Avatar
ReadRam
Mechanic friend of mine checked pressure and no leaks. Evap core is plugged up and water, when it's working is leaking on passenger floor. He blew some air up the drain hole and the air temperature dropped from 72 to 54 out the vents. Also air flow increased greatly. But, was short lived, must be clogged up again. Any way to blow or suck dust etc. out of there?
