No Overdrive
Old Jul 9, 2012 | 01:45 PM
blue02ram4x4's Avatar
blue02ram4x4
Default No Overdrive
I have a 2002 Ram 1500 with a 46re trans. Just finished rebuilding it, and no overdrive. The original problem was the snap ring broke in the over drive section. I put all new clutch's and steels. I also had to new bearing and direct drive drum in the overdrive section as well. I notice will driving highway speeds going 60mph, its not shifting into overdrive. RPM's are between 2500 and 3000. If I turn overdrive off the rpms will change slightly. Before the rebuild I had all forward gears, OD included, just no reverse. Any ideas?
Old Jul 9, 2012 | 01:47 PM
Did you replace the O/D solenoid? Might have gotten the wrong part. The pinouts on the connectors changed a couple times......
Old Jul 9, 2012 | 01:51 PM
blue02ram4x4
No I didn't change the solenoid. The only other parts I changed was pump and converter
Old Jul 9, 2012 | 02:30 PM
Need to find out if the PCM is actually commanding O/D then. And if it isn't, why not..... Got a scanner?
Old Jul 10, 2012 | 10:43 AM
blue02ram4x4
The CEL finally came on while driving back and for forth to work last night. No 3-4 upshift.
Old Jul 10, 2012 | 11:35 AM
redneck_ram's Avatar
redneck_ram
swap out the solenoid then. i have the same problem, but for a different reason. i put a 98 trans, in a 2001 truck, and the sensors and solenoids are a bit different. i finally just ordered all the right parts last night, including a drain plug!
good luck with fixing it!
Old Jul 10, 2012 | 02:01 PM
gdstock's Avatar
gdstock
Did you meaure the OD unit shim? The thickness required may be different with new clutches. Measurment is pretty critical.
Old Jul 11, 2012 | 12:44 PM
blue02ram4x4
I did. I think I figured out the problem. The o-ring that goes around the overdrive piston is backwards, so the fluid is bleeding past it.
