Gauge face install
Old Jul 15, 2012 | 12:34 AM
VinsBlackRam's Avatar
VinsBlackRam
Default Gauge face install
So i got an after market gauge face for my 98 dodge ram cause im sick of how this one looks. is it hard to install them, removing the needles wise? do you just pop the needles of and then put them back on or is there a trick to it?
Old Jul 15, 2012 | 01:05 AM
97ram318slt's Avatar
97ram318slt
Witch Guage faces did you buy and you will more than likely need to take them off most pop of with a small amount of force. good luck be shure to post before and afters if possible
Old Jul 15, 2012 | 09:36 AM
Sooper's Avatar
Sooper
The needles do just pop off but they need to be pryed carefully from the bottom as close to the shaft as possible. Also, it's best to remove them with the engine cold and everything off. Mark their position because even though they are electronic cycle gauges the readings can be off later if you get them put back on in the wrong alignment.
Accessing the gauge pod is easy. Remove the dash face. Unscrew the gauge pod, unplug it, open it up, remove needles, replace face, and put back together.
Some after market faces do not have all the same color filters as the stock face. All the bulbs behind the face are standard incandescent bulbs. If you like a specific color filter for a specific light, cut it out and tape it to the back of the new face to retain the filter color for that light.
Old Jul 15, 2012 | 07:35 PM
VinsBlackRam
all the filters on this new one are blue i believe
Old Jul 15, 2012 | 08:32 PM
gdstock's Avatar
gdstock
I put a chrome trim piece on mine which did not necessitate removing needles from gauge. (nearly the only piee of chrome on my Ram now...)
What did you get? can you post a pic?
Old Jul 16, 2012 | 12:53 AM
VinsBlackRam
idk if this brought up the picture so heres the link http://andysautosport.com/dodge/1994...m00000095.html
Old Jul 16, 2012 | 01:21 AM
99dodge318's Avatar
99dodge318
Definitely need some before and after pics!
Old Jul 25, 2012 | 02:09 AM
VinsBlackRam
Heres the gauges installed
Old Jul 25, 2012 | 02:10 AM
VinsBlackRam
okay i dont know how to add a pic to a thread so if anyone wants to see it ill add it to the album of my current truck on my profile.
