Help replacing front right universals/drive shaft.
Just back out the bearing assy bolt a bit keep your favorite socket on the bolt and hit with a hammer, work it like that until you push it out. The right way is using a zip gun with an adapter to hit the bolt the same way.
By the way 9/16 is 14.29mm, so basically a **** hair more lol.
