Newbie Dogde Owner
Old Jul 18, 2012 | 10:10 PM
Originally Posted by woods4life
I get going to the dana 60s but the double roller timing chain. Why would that be important to switch?
Stock timing chain is morse style. Rather prone to stretching, and, if you are over 100K, it's past time for a new one.
Double roller is more accurate, and less prone to stretching. Changing my timing chain and gears was the single biggest perceived performance improvement I had done for my truck. That was at right around 168K though...
Old Jul 18, 2012 | 10:51 PM
gdstock's Avatar
gdstock
With that many miles on your trans (if it is automatic) I would certainly do as HeyYou mentioned in earler post. Drop pan, inspcet for any junk, and swap out solenoids, If it is slipping, a rebuild will certainly be coming with larger tires and gears...
Old Jul 19, 2012 | 10:49 AM
woods4life's Avatar
woods4life
It is automatic. Any general estimate on a rebuild for a tranny?
Old Jul 19, 2012 | 12:21 PM
Anywhere from 1200, to over 2 grand. Depends a lot on what rates are like in your area... Finding a trustworthy transmission shop can be fun too....
Old Jul 19, 2012 | 12:26 PM
woods4life's Avatar
woods4life
That is kind of what I was figuring. How hard is it to find d60 stuff? What do those prices look like?
Old Jul 19, 2012 | 12:27 PM
woods4life's Avatar
woods4life
Originally Posted by 97ram318slt
Plenum~stickied thread
Gear Ratio ~ Search it
Double Roller timing chain
I dont know it all but some others will chime in.
Also fill in your signature with your truck info so you dont have to type it and to help us all out when giving you help User CP> Edit signature
ahhhh figured it out! yesssss
Old Jul 19, 2012 | 12:31 PM
D60 stuff is readily available online.... for the new stuff... Finding it used is a bit of a chance thing. In some places, the stuff is everywhere, others, rare as hens teeth. They were common axles under a fair few trucks.... but, you would need on out of a dodge, to make the swap easy. They were under all second gen 3/4 and 1 tons.... rear depended on weight rating, and engine/trans combo. There is a thread that goes into detail on that in the faq section.
Last time I was at the yard, there was a 97 sitting in there, with D60's under it.... most of the rest of the truck was gone, but, the axles were still there. They CAN be found, just gotta look, and be patient.
Old Jul 19, 2012 | 01:23 PM
Ryandodge2's Avatar
Ryandodge2
What i would do is check over the whole truck good, change all the fluid top to bottom, and check all the common problems everyone has mentioned above!
Old Jul 19, 2012 | 01:28 PM
97ram318slt's Avatar
97ram318slt
Check craigslist in baltimore there was a couple of listings. Like HeyYou said check out the junkyards too.
Old Jul 19, 2012 | 02:53 PM
malrick's Avatar
malrick
http://orlando.craigslist.org/pts/3148710175.html
if that gives you an idea of prices on craigslist it is 3rd gen but has disc brakes would be nice improvment on stopping.
