Fog light problem
Old Jul 21, 2012 | 04:07 PM
Dave Flick's Avatar
Dave Flick
had the same problem,used a test light no power when switch was off and power to them when it was on but no lights,so i just cut all the wires ran one side to a ground the other to a relay and new switch in cab
Old Jul 21, 2012 | 05:17 PM
RageGuy's Avatar
RageGuy
I had the same issue for many weeks. Replaced bulbs, fuse, relay, nothing worked.
If the switch is bad, i am told the little fog light indicator will not come on when you switch the fogs on, mine did so I did not replace the switch.
I had to trace the wires back with a volt meter, finally found one that was rotted out, fixed er up and booyah!
Old Jul 21, 2012 | 05:54 PM
My360's Avatar
My360
Thanks for the tip Billcart. I was thinking 4.10's but wasn't 100% sure on that.
I'll give that a shot, DK-v1
RageGuy, I wish I had that problem. The light doesn't come on on mine. I also checked all the wires, not a split anywhere. I'm going to try replacing the switch and cross my fingers that that's my problem.
Old Jul 21, 2012 | 10:18 PM
RageGuy's Avatar
RageGuy
If the fog lamp light doesn't come on id bet its your switch.
Try a wrecker / pick a part first, might get lucky
Very easy install, Just pop off the bezel and switch screws on / off. Remember to disconnect neg battery first!
Old Aug 9, 2012 | 08:47 PM
My360's Avatar
My360
Ok, so bought a new switch... didn't fix anything. Followed all the wires, they are all in good shape. What the hell is wrong?! When i pulled the switch, there were three connectors. The big one for the lights and two small ones (both the same size and both fit into the small plug). One had a green with black tracer wire and a black wire. The other had a yellow with black tracer and orange with black tracer. Anyone have a wiring diagram for fog lights?
The fog lights both run blue with black tracer wires. where the hell has this green wire come from? Fuses are good, relay is good..... I'm so damn lost on this one. Any help will be so nice.Attachment 16909
Attached Thumbnails Fog light problem-imag0187.jpg   Fog light problem-imag0186.jpg
Old Aug 9, 2012 | 09:14 PM
My360's Avatar
My360
After doing some searching... I got a question. If there's power to the fuse and relay... that must leave bad wires.... but I haven't found and rotten wires. BUT, where the wires "Y" there's a shrink wrap sleeve. Apparently the connection fails? I didn't cut into that so I don't know if there's a splice in there. Would that most likely be my problem?
Old Aug 9, 2012 | 10:20 PM
DK-v1's Avatar
DK-v1
Grab a wiring diagram from the DIY section. Without that, you're just p*ssing in the wind
It feeds from the actual light switch, so you need to make sure that your running lights are on when testing.
Old Aug 10, 2012 | 10:50 AM
My360's Avatar
My360
Yep, had the light son while testing. I searched the DIY's and couldn't find a diagram though.
Old Aug 10, 2012 | 11:05 AM
Download the 01 service manual from the thread in the faq section. Wiring diagrams are in there.
Old Aug 10, 2012 | 03:09 PM
My360's Avatar
My360
Found it. It's got a diagram for fog lamps except DRL and fog lamps DRl. Whats DRl?
