1997 dodge 2500 transmission problems
Old Jul 20, 2012 | 10:08 PM
armystrong1928's Avatar
armystrong1928
Default 1997 dodge 2500 transmission problems
Hi i got a 1997 dodge 2500 with the 46re transmission have a problem with it in third and fourth gear. it will shift into third for a quick second after i let off the gas while in 2nd then jumps straight to fourth gear. but it has no power to pull in third or fourth it just looses speed and if you push the gas it drops straight down to second gear.
Old Jul 20, 2012 | 10:11 PM
When was the last time the fluid was changed?
Old Jul 20, 2012 | 10:26 PM
armystrong1928
did the fluid change last weekend along with filter and speed sensor.
Old Jul 20, 2012 | 10:30 PM
Recheck your fluid level. Keep in mind, you have to check it in neutral. Checking in park will give you a false reading.
Old Jul 20, 2012 | 10:44 PM
armystrong1928
fluid is good still
Old Jul 21, 2012 | 08:33 AM
What speed is it shifting into fourth at? Shouldn't even try below 45 MPH or so.
Old Jul 21, 2012 | 11:27 AM
armystrong1928
It shifts anywhere from 45 and up but like I said you push the throttle to speed up drops all the way down to second
Old Jul 21, 2012 | 12:09 PM
Try adjusting the TV cable. Procedure is in the service manual. (and posted on the forums in several threads as well... but, the search isn't the best here. )
Old Jul 21, 2012 | 01:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not saying it's the problem, but , in this thread is the factory adjustment. https://dodgeforum.com/forum/2nd-gen...-in-trans.html
and in this link , it says how to screw around with it. http://www.bionicdodge.com/Download/...Adjustment.pdf
Old Jul 21, 2012 | 01:52 PM
KOS762's Avatar
KOS762
Throttle postioning Sensor... located under the air cleaner on the Side of the Intake plenum. Easy $35.00 fix. It does know where your gas pedal is... must have a dead spot in it. All or none usually works because is unused ( how often you have it pedal to the metal?) The common area of use is worn out. Thats why it jumps as if you are flooring it.) Hope this helps. KOS
