ABS/Brake light/No Cruise????
Old Jul 21, 2012 | 02:26 PM
saleen288's Avatar
saleen288
Exclamation ABS/Brake light/No Cruise? **FIXED**
Hello,
i have a 98 1500 5.9 360 4x4 last night my cruise would turn on but wouldn't set, and today my abs and brake light are on with no check engine light. i took it to my local parts store and used a reader no codes, my speedo, odometer work, my fluids are good my brakes are newer no leaks, my pedal feels great no problems stopping. Im lost please help......
Thanks
Old Jul 21, 2012 | 02:31 PM
Two or Four wheel ABS?
zman17's Avatar
zman17
Retired Moderator - RIP
You have a vac leak for the cruise most likely. Check the vac line to the cruise servo under the battery tray. And read this thread. Could be a vac leak elsewhere. https://dodgeforum.com/forum/2nd-gen...ild-vents.html
As far as the ABS and brake lights go, you either have a leak/pin hole in the brake line running next to fuel tank or the sensor on the top of the rear diff is bad.
Old Jul 21, 2012 | 02:34 PM
saleen288's Avatar
saleen288
I think its just two how do i check for sure?
Old Jul 21, 2012 | 02:36 PM
saleen288's Avatar
saleen288
hmm i did that check valve stuff last year, do i just pull the hose off the cruise and see if it has vacuum while the truck is running?
Old Jul 21, 2012 | 02:37 PM
zman17's Avatar
zman17
2 I'd say, but look and see if you have wires running to the front brakes. And get one of these, it's called a build sheet. http://www.dodge.com/wccsapp/univers...ull&category=U
Old Jul 21, 2012 | 02:38 PM
zman17's Avatar
zman17
No, you see if you have broken/ rotted lines or bad "check valves". A year makes quite a difference.
Old Jul 21, 2012 | 02:41 PM
saleen288's Avatar
saleen288
its two there is no wires to the front brakes.
Old Jul 21, 2012 | 02:43 PM
zman17's Avatar
zman17
Like I said as far as the brakes go anyway. " As far as the ABS and brake lights go, you either have a leak/pin hole in the brake line running next to fuel tank or the sensor on the top of the rear diff is bad"
Old Jul 21, 2012 | 02:44 PM
saleen288's Avatar
saleen288
ok well ill check for pin holes and pick up a sensor for the rear diff and get back to you, i sent the info for the build sheet.
