Going to burn the whole thing
Old Jul 22, 2012 | 10:29 PM
gdstock's Avatar
gdstock
Originally Posted by 95RAM360
Its always worth fixing....its probably something small and easy to fix...id try a new crank sensor like stated above
+1. Like I stated earlier, you most likely have a couple problems, and they may be overwhelming. Take one thing at a time and you will make progress.
Old Jul 23, 2012 | 12:40 AM
dodge_ss/t's Avatar
dodge_ss/t
check the crank sensor one more time, if its got any scratching or gouging on it the flex plate ate it, this can be caused a few ways, one that no one ever checks is if it had a tyranny replaced check to make sure the the trans bolts to the block are tight, if they back out any and let it sag it lets the flex plate eat the sensor in no time and causes a lot of what your saying and it doesn't take much. 2 theirs an imperfection on the flex plate. i have had both of thous situations come through my shop.
Old Jul 23, 2012 | 08:53 AM
wjxavier's Avatar
wjxavier
i'm betting that if you changed the CPS, and it started up and ran fine for one minute, thats probably how long it took for the flexplate to eat the new sensor. i'd check the flexplate to make sure its not warped or jacked up lol
Old Jul 23, 2012 | 02:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'll go with defective crank sensor also. Duralast I bet.
Old Jul 23, 2012 | 03:32 PM
TheBullRoars's Avatar
TheBullRoars
Borg warner w lifetime warranty. Going to pull it tonight when its not too hot out. Btw of all the ways to try to reach the cps, pulling the valve cover and going from the top is easiest
Old Jul 23, 2012 | 07:09 PM
Big Lar's Avatar
Big Lar
New Member
I'd take a peek at a few of the plugs and see if it's running too rich, if so check the ECT sensor behing the thermostat housing to make sure the 2 wires are connected.
Old Jul 23, 2012 | 07:58 PM
TheBullRoars
Got new ect sensor as well. The entire harness is solid and like-new all around
Old Jul 24, 2012 | 05:05 PM
TheBullRoars
New crank sensor, little to no change. Idles slightly higher and sometimes seems slightly better. Other times it misses and backfires w no power and wot won't go past 3k RPM. Still takes a couple cranks on warm starts. Still no o2 sensors. Not doing exhaust till the running condition is figured out. Ref running rich for that reason but there seems to be a different issue
Did a compression check and the only cylinders not at 150psi were the first three on the drivers side which were all around 130-135. With a little oil they were back at 150
Old Jul 24, 2012 | 05:40 PM
Compression is pretty good though, and well within spec.....
Remove the front O2 sensor from the exhaust. (hang it out of the way, or, unplug it, and toss it in the truck....) Take it for a drive. See what ya get.
Old Jul 24, 2012 | 05:57 PM
TheBullRoars
Did that already. Cat was clogged and wouldn't allow truck to run. Started up w the o2 bung open. Still stumbled bad tho.
Stuck in (open?) loop now w exhaust cut off and replaced without oxygen sensors.. for the time being until it starts every crank and doesn't stumble and missing
Plug wires are routed properly
Previous to stalling and running/ no start issues i installed a 180 degree thermostat which I now read can cause the pcm to dump more fuel but I don't think it made the truck stall and it never got too hot
