2000 Dodge Ram 5.9 wont start
Old Jul 22, 2012 | 03:55 PM
kodiac78's Avatar
kodiac78
Default 2000 Dodge Ram 5.9 wont start
I changed the temp senseor on my Ram and when I put it back together it would not start. The gauges will not work and sometimes the odometer flashes then other times it says no bus. No fire but will turn over.
Codes are: p0505, p0123, p0118, p0113, p0463 and p1492
Anyone have any ideas?
Thanks
Old Jul 22, 2012 | 03:57 PM
Is the temp sensor the ONLY thing you did? Just remove the old one, and install the new one?
Old Jul 22, 2012 | 03:59 PM
kodiac78's Avatar
kodiac78
Yeah, I had to unbolt the alt to get to it. once I replaced it I put all back together and now wont start.
Old Jul 22, 2012 | 04:50 PM
Check and make sure everything is hooked up correctly at the alt. There is a ground there that is kinda important.....
If you are getting no bus errors, you missed a trick somewhere.
Old Jul 22, 2012 | 05:06 PM
kodiac78's Avatar
kodiac78
I hooked up the ground and the plug on the back.
Not getting the no bus now but gauges still not working and still no spark.
Old Jul 22, 2012 | 06:10 PM
Where are you checking for spark, and how?
Old Jul 22, 2012 | 06:36 PM
kodiac78's Avatar
kodiac78
With screwdriver and plug wire while turning it over.
Old Jul 22, 2012 | 06:58 PM
Pull one of your sparkplugs, stick it back in the wire, and ground it on the intake somewhere. Hold it in place with a stick of some sort. (non-conducting please....) see if you get spark that way. Also test in the same manner, with the coil wire.
Is your temp sensor plugged back in??
Old Jul 22, 2012 | 07:10 PM
kodiac78's Avatar
kodiac78
I will try that.
I plugged the temp sensor back in. The plastic on the old one broke when I disconected it, you think the plug may be bad? That wouldn't keep it from starting would it?
Old Jul 22, 2012 | 07:22 PM
It should still have spark, but, it may not wanna start....
