Air Conditioner/Heater Blower Problem
Old Jul 22, 2012 | 05:43 PM
SouthernBoy 98's Avatar
SouthernBoy 98
Default Air Conditioner/Heater Blower Problem
I have a 98 Ram 1500, 5.9. Having problems with Air Conditioner/Heater Blower. Someyimes it blows, sometimes it does not.
If I leave it on, it will sometimes just start running. Once it it running, it will run until I turn it off, and then may or may not have the same problem when I turn it back on.
Is it the control switch on the dash that needs replacing?
Thanks for any help!
Old Jul 22, 2012 | 06:11 PM
Dash switch controls ground. When the blower ISN'T working, see where you are losing power at.
Old Jul 23, 2012 | 01:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the resistor is going bad. But you have some testing to do. Download the service manual from the FAQ/DIY section. Wire schematics are in it. And , if you need a new control panel, I have one available out of a 98.
Old Jul 24, 2012 | 06:33 PM
SouthernBoy 98
Hey Guys,
Thanks for the direction, escpecially to zman17 for the direction over to the DIY section (helps alot)! I'm new here (only found this forum about a week ago). Will let you now what i find.
