Restoration of My Dodge
Old Jul 25, 2012 | 08:47 PM
QuadCabLuv's Avatar
QuadCabLuv
yeah good luck with that. Unless your wife is a body builder then i dont think the 2 of you will be enuff.
Old Jul 25, 2012 | 09:11 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by 95RAM360
Ok....i dont have much help around here....ill have the wife take the bed off
if you don't have enough muscle to lift it, build some saw horses or brackets in fence posts to hold some cross boards. jack up on end at a time and get a cross board under it. then drive out from under it.
i don't think you need to remove the bumper first.
Old Jul 25, 2012 | 09:18 PM
LegendKiller89's Avatar
LegendKiller89
dhvaughan brings up a great idea! No you do not have to take the bumper off first. At least 3, four would be great to do the bed. It ain't light trust me, I've done it a number of times.
Old Jul 25, 2012 | 10:00 PM
95RAM360's Avatar
95RAM360
I do have help...just hard to get them over cuz i live in the sticks...
Going to attempt to get bed ready for removal and take out bad control arm tomorrow..
And by the way can i change the control arm with all 4 tires on the ground or do i need to jack it up
Old Jul 25, 2012 | 10:24 PM
stewie01's Avatar
stewie01
Probably depends on how many floor jacks you have, as you'll have to deal with the spring, right?
Old Jul 25, 2012 | 10:43 PM
QuadCabLuv's Avatar
QuadCabLuv
You need to jack up the side you are working, make surr to place the jack on the frame. This way when you jack it up the coil will fully extend and it wont have very much tention left on it, makes it easier to just yank out without having to use a spring compressor. Of course all of this is based off of my experience with 2wd's, but im assunibg that the spring is perched on either the upper or lower control arm.
Old Jul 30, 2012 | 03:27 PM
95RAM360's Avatar
95RAM360
Ill be able to remove control arm without removing spring...
Now i just found that new control arms with bushings are only $35...now i have a clunking sound evertime i go over bumps....all front end parts are new and shock tower is tight...now i assume that this sound can be caused by the bushings...if so then ill just buy all new arms....but before i do can anyone tell me what else could cause the clunking? Dont want to buy all new arms if i dont have to....only have 1 arm that needs replacing and i can get it for free...so im open to suggestions
Old Jul 30, 2012 | 05:15 PM
lastrights's Avatar
lastrights
Surprised to see u still have this truck ! Lol
Old Jul 30, 2012 | 05:31 PM
merc225hp's Avatar
merc225hp
Mark the cam bolts, release the cam bolts, set so that there is no tension on the control arm and remove it. Do one at a time, no jacking, lifting or prying will be needed.
Old Jul 30, 2012 | 07:12 PM
Ol_RedRam's Avatar
Ol_RedRam
And how many people do you guys think is needed to remove the bed? And do i need to remove bumper to get bed off
Two guys can do it. It's tough, but it can be done. My dad and I did it a few weeks back and neither of us are big guys. Three guys can handle it easily.
Hard part was putting back on and getting everything lined up. Get a long 2x4 and make good use of it.
