axle shaft stub/nut question
Old Jul 27, 2012 | 12:49 PM
merc225hp's Avatar
merc225hp
What part are you looking for?
Link http://quad4x4.com/Dodge1500Dana44front1994-2001.html you can also check your local jy.
Old Jul 27, 2012 | 12:54 PM
mideerslayer's Avatar
mideerslayer
http://quad4x4.com/qk4732.html
This is what I'm looking for
Old Jul 27, 2012 | 12:58 PM
merc225hp's Avatar
merc225hp
Up here that is a dealer only part and get this $50 for each nut. Any JY out there? if so go get a unit bearing assy with the stub shaft. Once those threads start to gall they are done for.
Old Jul 27, 2012 | 11:27 PM
dhvaughan's Avatar
dhvaughan
i've gotten parts at alljeep for really good prices.
call them if you don't see it online (it helps a lot to have a dana/spicer part number)
http://www2.dana.com/pdf/X510-5DSD.pdf
http://www.alljeep.com/oscommerce/pr...ucts_id=167605
Old Sep 11, 2012 | 04:50 PM
HeikIlm's Avatar
HeikIlm
Anyone happen to know the thread size on stub shaft? It's about 28.2 millimeters od, which is about 1.11" (or 1-7/64"?), TPI maybe 18.
I need only one nut, but shipping it overseas is pricey, from $40 to $105!! I did contact local Dana/Spicer dealer with part number, but they have not gotten back to me yet. So I thought about getting one turned, I just need exact numbers to get it right.
Old Sep 12, 2012 | 08:43 PM
VEETEN's Avatar
VEETEN
FWIW all the Danas are metric, the nut is 43 mm.
So HeikIlm put a set of thread gauges on there and see what it shows.
Just a guess here 28mm-1.5. THIS IS JUST A GUESS THOUGH TO GET YOU STARTED.
Thats probably a stock part over in Europe. Cheers
Old Sep 16, 2012 | 06:27 AM
HeikIlm's Avatar
HeikIlm
I thank you! Two years ago when I changed the RH hub, I managed to mangle the thread so that it was almost fubar'd, but got it back and torqued. Now when I changed the axle shaft seal I noticed that bearing makes some noise so I didn't get the torque just right. Bad thread, so torque wrench reaches set point too early.
Back then I tried to get a new one, but thinking it's not metric thread (even though I measured it) I didn't find anything. But now I took a thread file which shows the pitch, and it actually is M28x1.5! So far I haven't found nothing, at the big rig shop there was TRE nuts, but biggest one was just a shy off M27x1.5. I send email to specialty bolt shop, hopefully they have something to offer. If not, I just get couple of them custom made.
