axle shaft stub/nut question
Old Jul 26, 2012 | 09:32 PM
mideerslayer's Avatar
mideerslayer
Default axle shaft stub/nut question
Ok when I got around to taking the the hub off to replace the u-joint, the axle nut/castle nut was rusted on to the point I had to burn it off.
Well in the process I mess up a thread or two, and there is a spot where there is no thread so I cant take it and get it "tapped" or what ever the term is.
So I was wondering could I put washers on up to the cotter pin hole and instead of a cotter pin, get a grade 8 bolt and nut and put that in place of the cotter pin?
I don't take it off road, It isn't driven all to much, and I cant find that part locally
Thanks
Rich
Old Jul 26, 2012 | 09:45 PM
dhvaughan's Avatar
dhvaughan
the messed up threads are where - where the nut goes, or outside of that?
will it torque down to whatever the spec is (150-175 or so) ?
if so it'll probably be ok
you must have a high torque on that nut. you can't rely on a cotter pin or thru-bolt to hold the nut on. your life depends on it.
if it won't torque down in the normal nut position, you'll have to shim out some threads and tack weld the nut, or get a new stub shaft. (junk yard)
edit - did not mean to imply that you could weld it on without torquing it. you can shim it out - torque it - then tack weld it if its too far out to catch the cotter pin hole. but you must have proper torque on the nut.
Old Jul 26, 2012 | 09:47 PM
No. Part of torquing that nut to the proper value is... it holds the hub/bearing together. It NEEDS to be on there at 180 or so lbs feet, else the bearing will self destruct in short order. (never a good thing.....)
Old Jul 26, 2012 | 11:02 PM
BLACKSHEEP757's Avatar
BLACKSHEEP757
Used stubs up for grabs from mine as of today......pm me if you need em.......mine came off nicely
Old Jul 26, 2012 | 11:04 PM
BLACKSHEEP757
Oops ......didnt see sig before replying.......mine are for a d60.....srry
Old Jul 27, 2012 | 10:08 AM
mideerslayer
Well I cleaned it up with my dremel and it isnt as bad as I thought, does anyone know off hand what size nut it is?
I looked around and it seems that it is 1 1/16" but not sure on the thread, maybe 1/4-20?
Thanks
Rich
Old Jul 27, 2012 | 10:15 AM
redneck_ram's Avatar
redneck_ram
Thanks
Rich
nut is 1 11/16. thread size in nowhere near 1/4-20. its over an inch in diameter. how did you come up with 1/4-20?
Old Jul 27, 2012 | 10:33 AM
mideerslayer
I was just using 1/4-20 as a refereance to thread size, i know its no where close to that but its the first size i though of.
I did a little googling and I came up with 3/4"-16 thread 1 1/16 diameter nut, does this sound about right?
Old Jul 27, 2012 | 10:36 AM
redneck_ram
nut is 1-11/16... the shaft is more than an inch in diameter. go out and measure it.
Old Jul 27, 2012 | 12:26 PM
mideerslayer
Is this a dealer or on-line order part? I cant seem to find one at the local auto parts places
