hard starting
Old Jul 27, 2012 | 09:09 AM
piemxzhome's Avatar
piemxzhome
Default hard starting
I have a 1997 dodge ram 1500 sport with the 5.9L when i first got it you only had to crank it for a few seconds before it ran and now it has to crank for maybe 30 seconds before it starts any ideas what wrong
Old Jul 27, 2012 | 09:39 AM
Check fuel pressure at cold start.
Old Jul 27, 2012 | 05:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... Fuel pressure regulator is bad. Which is part of the fuel pump.
Old Jul 27, 2012 | 09:33 PM
piemxzhome's Avatar
piemxzhome
Where is the fuel pressure regulator on the truck
Old Jul 27, 2012 | 09:45 PM
stewie01's Avatar
stewie01
Did you read zman's reply? It's part of the fuel pump.
Old Jul 27, 2012 | 10:12 PM
piemxzhome's Avatar
piemxzhome
I must be blind but is there a way to check it or just replace and see if it makes a difference
Old Jul 27, 2012 | 10:30 PM
stewie01's Avatar
stewie01
Well I'm not sure if that's a part you can replace separately or if you have to purchase a whole new pump.... One of the guys will know.....
But a fuel pressure test is the best way to test it. See how long it takes to build pressure and how fast the rails loose pressure and what the running PSI is.
Old Jul 27, 2012 | 10:54 PM
dhvaughan's Avatar
dhvaughan
with ignition turned to on, test the fuel pressure at the test port on the fuel rail, drivers side of engine. looks like a tire valve. should be 49 psi +/- 5
if not up to spec, replace fuel pump assembly, conveniently located..... in the tank. to replace, drop the tank or raise the bed. i think its easier to raise the bed, that way you can test it before dropping the bed, vs having to raise the tank and reconnect.
Old Jul 27, 2012 | 11:53 PM
He has a 97..... isn't that the year that had the plastic fuel rail that DIDN'T have the pressure test port?
Old Jul 28, 2012 | 06:26 AM
dhvaughan's Avatar
dhvaughan
i don't know. for his sake i hope not.
