ABS always engage
Old Jul 30, 2012 | 01:38 PM
BigDaddyPT's Avatar
BigDaddyPT
Default ABS always engage
99 Dodge Ram 1500 Laramie w/ 4 wheel ABS.
My ABS and brake light has been on. I replaced the rear sensor on the differential, both wheel bearings and ABS sensors. When running the driver's side ABS sensor, I noticed that the old one was unplugged. My initial thought was "what idiot would unplug this?"
I plugged in the new sensor and the ABS and brake light went off. However, immediately after taking it out for a drive I realized why it was unplugged.
Anytime I brake, the ABS engages. I am driving at a slow speed on dry, smooth pavement and there should be no reason for them coming on. Any thoughts?
Thanks in advance...
Old Jul 30, 2012 | 02:04 PM
Check and see if dodge doesn't have some updated software for the ABS system. Could be one of your sensors isn't telling the module the truth too.... would need a scanner that would show sensor data to determine that, and which one though.
Old Jul 30, 2012 | 05:51 PM
BigDaddyPT's Avatar
BigDaddyPT
You're probably right about the data from the scanner, but I have a hard time thinking that updated software might solve this.
Does anyone know if this could be a bad module?
Old Jul 30, 2012 | 07:35 PM
Entirely possible.....
