got some questions
Old Jul 31, 2012 | 02:22 PM
wjxavier's Avatar
wjxavier
Default got some questions
Ok, just wanted to throw this out there and see if anyone had some answers.
my first question is this, should i go back through the bolts on my intake manifold and do a torque check? kinda like exhaust manifolds? just curious.
second question: my truck wont down shift from 3 to 2 when i accelerate. if i come around a corner and hit the gas, or even if i just want to pass someone, i have to manually downshift. any ideas on what that could be? i have a '95, so its an RH. something clogging a passageway in the VB? is there a kickdown solenoid? i dont think there is, but just wanting some advice or opinions on what it might be.
any info is appreciated! thanks!
Old Jul 31, 2012 | 02:31 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I'll answer with a question.
After 1000+ posts by you and the support you've gotten here on balljoints (loved that thread actually) and other issues, how did you succumb to the "I'm so lazy I'll make an obtuse thread title that no one can benefit from" syndrome?
Old Jul 31, 2012 | 02:36 PM
wjxavier's Avatar
wjxavier
i've been feeling exceptionally lazy lately, sorry lmao. if i could change the title, i'd do it just for YOU! lol!
Old Jul 31, 2012 | 02:57 PM
billcart's Avatar
billcart
Is there a gov pressure on rh? If so that might be it.
Old Jul 31, 2012 | 06:51 PM
wjxavier's Avatar
wjxavier
well, there's not a governor solenoid on the RH's i believe. but i've heard people call the O/D solenoid (which an RH DOES have) a kickdown solenoid as well. so i'm just kinda confused. funny part about it, is that ever since my O/D off hasn't worked, this problem has been there too. so i honestly have no clue what it could be...and really dont have the money to be dropping the pan, swapping parts that might not be the problem, and finding that it its not the problem, and then spending more money on fluid again lol. i'm pretty convinced its my solenoid, but just wanted some opinions first before i decided to move ahead with anything lol
Old Aug 1, 2012 | 09:22 AM
Check TV cable adjustment. That's about the only thing that is going to affect shift points on an RH.
Old Aug 1, 2012 | 10:40 AM
95RAM360's Avatar
95RAM360
Im just throwing this out there....your fluid is up to par right...your saying you have ahift problems and i remember a time where i went offroading and loaded my tranny up with water...drove it home 12 miles with the truck not comming out of first and slipping and grinding....flushed it four times by just filling it, running through gears and dropping the pan...and the last flush i changed the filter and boom...havent had a single shift problem since....and that was about 20k ago...thats why i ask about fluid/filter
Old Aug 2, 2012 | 08:24 AM
wjxavier's Avatar
wjxavier
it has been a while since the fluid and filter has been changed, but its been having this problem since before i changed the fluid last. and i've adjusted the TV cable multiple times and it still wont downshift from 3-2 unless i come to a crawl, maybe 10 or less mph.
Old Aug 2, 2012 | 08:36 AM
Drop the valve body, clean it, and check for broken springs.....
Old Aug 2, 2012 | 08:56 AM
wjxavier's Avatar
wjxavier
will do, thanks!
