Gutless on the highway
Old Aug 1, 2012 | 11:32 AM
RageGuy's Avatar
RageGuy
Default Gutless on the highway
Truck is gutless in OD when out on the highway, unless I stomp on it thereby booting it down a gear out of OD.
Also, the ammount I have to push the pedal down to get it to kick out of overdrive doesent feel right...I have to nearly put it to the floor.
Any ideas?
TPS is new, Thought maybe it was that but nope.
Old Aug 1, 2012 | 12:13 PM
kejobe's Avatar
kejobe
Did this just start? If so, could be clogged cat. Unscrew the pre-cat o2 and tie it up out of the way. Drive it and see if its any better.It will be louder but thats fine for the test. If it runs better youll need to either gut or replace the cat.
If its been doing this since you got the truck or since any work has been done, the tv cable could be out of adjustment.
Also check out the plenum thread at the top of tech section. This could contribute to the problem also.
Old Aug 1, 2012 | 12:23 PM
RageGuy's Avatar
RageGuy
Been doing it since I bought the truck, just dont take it on the highway much so it never really bothered me till now.
Cat is brand new (Sorry forgot to mention that in my signature)
Is there a document somewhere on how to adjust the TV cable? That is a delicate operation if memory serves me correctly...
My Plenum is fixed with the hughes kit.
Old Aug 1, 2012 | 01:00 PM
Ham Bone's Avatar
Ham Bone
OD is a really weak gear designed only for fuel economy. Now you may scoff at the mention of fuel economy with these trucks but go rolling down the interstate in third gear and see what happens.
It's also only made for flat or Nearly flat roads. Its just the way the gear is
If it pulls fine once it out of OD then nothing is wrong
Old Aug 1, 2012 | 01:22 PM
kejobe's Avatar
kejobe
Here ya go click on tech info. Its in there:
http://www.bionicdodge.com
Old Aug 1, 2012 | 02:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Factory adjustment for the TV cable in in this thread, https://dodgeforum.com/forum/2nd-gen...-in-trans.html
If you want to screw around with it here is the other link. http://www.bionicdodge.com/Download/...Adjustment.pdf
I doubt it's the problem anyway. If the plenum has been fixed and you have a new cat, you might want to do a compression test to eliminate a cracked head issue. Other than that, 3:55 gears are the problem most likely.
Old Aug 1, 2012 | 04:16 PM
Probably wouldn't hurt to replace the O2 sensors either....
Old Aug 1, 2012 | 06:16 PM
DPR250R's Avatar
DPR250R
Mine is the same way.... I have a 318.
It's fine on flat roads.... slight incline... downshift and rev. Very... very annoying.
Looking into gears or will just live with it till it is time to sell it.
Old Aug 1, 2012 | 07:31 PM
Nereaga's Avatar
Nereaga
^^^^ X2 I always pull it out of OD before the incline and all is good. I do lose some steam up BIG hills, which we have a lot of here in PA, but I'm going to be addressing the plenum come soon, we see if that helps.
Old Aug 1, 2012 | 08:59 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Some will rail on me for this but....
I did the zip tie throttle mod..
I put one zip tie on between the pedal and the end clip on the cable in the cab, and it really improved the performance. I wouldn't go more than one, but it really helped mine; I don't have to mash the gas as hard to get the truck to move.
