biggest lift cam with stock heads
Old Aug 5, 2012 | 01:36 PM
my99ram's Avatar
my99ram
Default biggest lift cam with stock heads
whats te largest cam i can run with the stock valve springs?
I have 5300 6671 heads on my 99 5.2
Old Aug 5, 2012 | 03:02 PM
Jr. Mechanic's Avatar
Jr. Mechanic
http://www.hughesengines.com/Index/p...3&partid=11442
That is basically an "RV" cam. You won't notice a whole lot of difference.
The stock springs are weak; an awesome combination is the HER0814AL cam, 1110 springs, 1278 retainers, and 1300 locks. This gives a slight lope at idle and an awesome power band.
Old Aug 5, 2012 | 03:35 PM
my99ram's Avatar
my99ram
i was gonna go with a comp cams cam
Old Aug 6, 2012 | 06:21 PM
my99ram's Avatar
my99ram
on a .480 lift would I need to change my springs?
Old Aug 6, 2012 | 07:01 PM
JoshSlash87's Avatar
JoshSlash87
I think most would agree it'd be a great idea to change stock springs even if you upgrade your cam an extra .25 lift lol. It seems theres not much love for the stock springs with people who have upgraded their cams or rocker arms even the smallest amount. I'm running a stock engine so I don't really have an opinion on the matter as my valves have never floated yet, I have to change my valve seals soon so I'll probably end up getting the 1.7 roller rockers so I'll deal with that then as well
Cam should have a description & recommendation for what it needs spring wise. It also depends on how many rpm's you're going to be running. I've heard people say they've done 6,000 Rpm on these stock magnum springs before floating, but I don't know their exact setup.
Old Aug 6, 2012 | 07:35 PM
my99ram's Avatar
my99ram
I want good low end torque,wont run more them 5800 or so,my stock motor rev limited at 6k( guessing someone increased the rev limiter)motors all stock except for the early 90's heads and cai and thrush muffler.
Old Aug 6, 2012 | 07:37 PM
my99ram's Avatar
my99ram
also when looking for springs what do I want to look for in inner dia. and outer dia..the lbs rate and od dia and installed height?
Old Aug 6, 2012 | 07:40 PM
QuadCabLuv's Avatar
QuadCabLuv
definitely go ahead and update the springs. They are not that expensive, especially for the peace of mind.
Old Aug 6, 2012 | 07:48 PM
Jr. Mechanic
I already gave you a tried and true setup for exactly what you want. If you would like to spend more money on a Comp cam that's fine, but you won't find a better deal on the correct springs, retainers, and locks that are a direct drop in for Magnum heads.
Old Aug 6, 2012 | 07:58 PM
my99ram's Avatar
my99ram
for springs i can go to summit and they start at 35 for a set of springs(just dont know what to look for in size).I was looking at a tfs kit with the springs,locks and retainers for 125.
that cam u said will it give me good tire smoking low end with my 3.55 gears?and would it have a noticable idle(I like the old muscle car sound)
