What is this relay for?
Old Aug 7, 2012 | 04:49 PM
RageGuy's Avatar
RageGuy
Default What is this relay for?
Or is it even a relay?
Blue box in this picture:
https://i.imgur.com/NHmf9.jpg
This is the in-cab fuse panel located between the drivers door and the dash.
This is the refrence diagram for the panel:
https://i.imgur.com/fDE37.jpg
No mention of what the blue box is for..
I was just curious....RWAL is not working, was just checking fuses and noticed this thinger.
Old Aug 7, 2012 | 05:01 PM
dhvaughan's Avatar
dhvaughan
i think its the flasher.
Old Aug 7, 2012 | 05:21 PM
dlyter09's Avatar
dlyter09
For the ejector seats..... on a serious note i think dhvaughan is right
Old Aug 7, 2012 | 05:28 PM
RageGuy's Avatar
RageGuy
It says bank 10 is the flasher though?
Ejector seats would be awesome for when the mother in law is riding shotgun.....
Old Aug 7, 2012 | 05:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Confirmed.
dhvaughan is correct.
What you need to check , is too make sure you don't have a pinhole in the brake line going to the rear of the truck and that the sensor on top middle of the rear diff is working(both are the most common probs).
Old Aug 7, 2012 | 05:41 PM
RageGuy's Avatar
RageGuy
Originally Posted by zman17
Confirmed.
Hey Thanks for the info.
How does one check if that sensor is working? And what's it called anyways?
Old Aug 7, 2012 | 08:47 PM
dhvaughan's Avatar
dhvaughan
its in the top of the rear end pumpkin, with an electrical connector.
its called rear ABS sensor, sometimes aka rear speed sensor. if its not working, it should set off a CEL light.
check cel codes by turning ignition to ON OFF ON OFF ON and then watching the digital odometer.
Old Aug 8, 2012 | 12:16 AM
RageGuy's Avatar
RageGuy
I have no codes, just checked with my reader.
