tcc code 37 guys that's had it&fixed it please.
Old Aug 9, 2012 | 03:32 AM
cutthroatxxx's Avatar
cutthroatxxx
Default tcc code 37 guys that's had it&fixed it please.
Ok fellas so this is the deal I get the code 37 tcc solenoid shortned or open or high trans temp sensor.Well since my truck dosnt have the tow package.So that's not a issue.Some guys on here have told me to ignore it but...if you've read my other posts the truck shakes around 45&don't think I have a miss so I'm thinking maybe I shouldnt ignore it.Pretty sure I'm gonna swap it out incase that's it before it causes bigger problems.
That being said who has gotten this code&how was your truck acting&did you replace the tcc solenoid...what were the results?Thanks
Old Aug 9, 2012 | 08:47 AM
On yours, if you have a trans temp sensor, it will be in one of the cooler lines, very near the trans. Check it out.
If TCC works....... I am not sure what the PCM would be whining about.... Changing the fluid/filter and solenoid set (O/D and TCC) sure wouldn't hurt.
See if that addresses the shudder as well.
Old Aug 9, 2012 | 12:35 PM
cutthroatxxx
No trans temp sensor
Old Aug 9, 2012 | 03:41 PM
cutthroatxxx
None of you guys have had this issue?
Old Aug 10, 2012 | 02:27 AM
cutthroatxxx
Man those parts are expensive Id hate to just throw parts@it
Old Aug 10, 2012 | 08:15 AM
Where are you pricing them from?
Check out Wittrans.com
Old Aug 10, 2012 | 11:08 AM
cutthroatxxx
ok Will do&from local parts stores
Old Aug 16, 2012 | 12:44 AM
cutthroatxxx
So nobody has dealt with this issue?
Old Aug 16, 2012 | 08:55 AM
Have you changed out the solenoid set yet? I seem to recall another member having this issue, and the problem was chafed wires inside the trans pan intermittently grounding out. Wouldn't hurt to drop the pan and have a look.
