bed sagging on one side
Old Aug 15, 2012 | 12:32 PM
merc225hp's Avatar
merc225hp
Just a heads up, when you go to change the rear leaf springs the drivers side is a PITA to do. You have to drop the gas tank to get to one bolt, fun.
Old Aug 15, 2012 | 08:27 PM
dhvaughan's Avatar
dhvaughan
^ another example of where I'd love to strangle a dodge (non)engineer.
Old Aug 16, 2012 | 12:45 AM
Wombat Ranger's Avatar
Wombat Ranger
Where would you have put the gas tank?
Old Aug 16, 2012 | 08:53 AM
How about simply putting the bolt in from the other side? Or would that have been too much work for the line worker to remember that bit?
Old Aug 16, 2012 | 12:10 PM
merc225hp's Avatar
merc225hp
Well I thought about welding the nut on the inside of the frame but as it's a leaf-spring bolt I figured this was not a good idea, things can be a bit** at the best of time to get out.
Old Aug 16, 2012 | 08:57 PM
Kaldir's Avatar
Kaldir
My truck also leans toward the driver side. When I went under it I saw that I had a broken leaf spring. At some point I want to replace the leaf springs on both side. Mainly comes down to $$$$.
Old Aug 16, 2012 | 09:11 PM
Wombat Ranger
Probably because you "don't slow down for speed bumps"
Old Aug 16, 2012 | 11:17 PM
Kaldir's Avatar
Kaldir
You could say that! The off roading doesn't help ether.
Old Aug 16, 2012 | 11:46 PM
dhvaughan's Avatar
dhvaughan
i looked at that again. my leaf spring bolts are a big torx head, maybe T45, T55. it looks like you might be able to get a torx socket on the end of a pull bar, and slip it in from the top, or inside the frame channel from the front or back. then put an air wrench on the nut and zip it off. maybe.
leaf springs sure are expensive
DAYTON PARTS EXTRA HEAVY DUTY LEAF SPRING, PROGRESSIVE RATE, SOLD INDIVIDUALLY -- 5 leaves; 2.5 in. width; 2600 lbs. spring capacity
part # 34-1339HD is the 2500 light duty (5+1, 2600)
my factory springs are (3+1, 1705)
check pricing here.
generalspringkc best price http://www.generalspringkc.com/Leaf_...001_s/1912.htm
stengelbros
sdtrucksprings
autoandtrucksprings
huskyspring
autopartswarehouse
Old Aug 16, 2012 | 11:50 PM
mantisman51's Avatar
mantisman51
Maybe it's a 4x4 thing. I removed the leaf spring on the drivers side and aside from losing a lot of knuckle and backhand skin, no difficulties. I was adding some add-a-leafs, though. So far the springs have held up to everything I've thrown, scooped or dumped in the bed.
